  Horological Discussions, Questions and Answers   Pocket Watch Discussions
  Pocket Watch Discussions   S.W.Co Movement
  S.W.Co Movement| Go   | New Topic   | Find-Or-Search   | Notify   | Tools   | Reply to Post   |   |
 Hello all, Had a great talk with Lindell on  this Sunday about this movement. Pulled this out of my drawer after maybe 20 years. Movement reads S.W.Co Springfield Ill. Model 1 full plate grade SWC & Diurnal course train. Pinned roman dail looks great. Nice hands. How rare might this  be?This needs a nice home.Will take trades. And any info someone have. Thanks Lindell. TED | ||
 Buy the way serial # is 84,242.This is a keywind & Keyset. Put a new roller jewel in it and its been running for the last two hours. Regards Ted | |||
| IHC Life Member Site Moderator  |
 Hi Ted I am not really sure about this info, without any photos to go by. Illinois made a movement called Diurnal, which was a 18s Key wind & set hunter 7 jewel. Supposedly they made 3 runs from 1876-1878 for a total of 4150. 80001-84100, 84901-85000, 85001-87000 The serial number you listed 84242, doesn't fall into those numbers but we all know the records are not exact. Your serial number is listed as a model 1 Key hunter Interior grade which was made in 12 runs from 1876-1878 for a total of 10,200. Yours was in run 84101-84300 but the run just before it was a run of Diurnal so perhaps the run numbers are off. Is your hairspring attached to the balance cock or is it attached to the bridge? Tom | |||
 Just saw this post from earlier this year where Tony had acquired one of these. https://ihc185.infopop.cc/eve/f...881029912/m/30510149 Tom | |||
 Hi Tom. Thanks for the info. The hairspring is attached to the balance cock. Great to hear from you. Regards Ted | |||
 Tom, The movement looks just like the one Tony Dukes but mine has S.W.Co and Tony,s has Diurnal.Ted | |||
 Ted Nice to hear from you too! This is the image from the gold book, EA452A , it says made only in grades SWC & Diurnal. Tom  | |||
 Usually the subject of a 7-Jewel Key-Wind makes me yawn  but this one is unusual and not at all as common as I thought at first glance. Looking at page 328 of the Meggers Illinois book Ted's number is out of sequence as Tom pointed out. Apparently it is essentially similar to the Diurnal... (where did THAT name come from?) But checking page 91 of the same book we find that some 5,800 of the S.W.Co. Grade were produced, and further that... "Grades 'S.W.Co.' and 'Interior' were the only grades made with a flat nickel three-arm balance wheel." The plot thickens...  | |||
 Lindell I had also wondered where the name Diurnal came from, I found where it has several definitions; Diurnal motion is an astronomical term referring to the apparent daily motion of stars around the Earth, or more precisely around the two celestial poles. Apparently it is also used as the word daily. Tom | |||
 Wow! This is fun.Thanks Lindell & Tom. Photo EA 452a also says it made with a expansion shape balance ( what is that )? | |||
 Ted I am just guessing but I wonder if they are referring to a compensated balance wheel, ie. a normal bi-metal cut balance? Tom | |||
 Tom, This  is not a compensated, its a three arm metal.  i have many old Walthams they called them under spung steel balance and it looks the same maybe thats just another name for it. Been watching it running and the hairspring is expansioning just like the old Walthams. Ted | |||
 Ted I was thinking they were saying it could come with either type, the solid 3 arm like yours or the two arm split. If you look at EA 452 it has the compensated balance but also says it was made with the three arm. Just all guess work on my part  | |||
