I purchased a really nice old Roskopf.. When I got it home, I tried to screw off the front and rear bezels to no avail. I looked at it with a loupe and noticed both had been glued into place... Does anyone have any ideas on how to remedy this problem??
Bruce Byrd
Posts: 888 | Location: San Diego, California USA | Registered: December 27, 2002
Very, very, very carefully use a Q-tip that is dipped in acetone to remove the glue. Be very careful not to get any excess acetone into the movement or especially on the dial. This might be a slippery slope
However since glue was applied, that raises a question...
Why did they glue it together?
Is it because the back and bezel did not fit properly and that why it is glued? I know Lindell has a tool to adjust the tightness but it is quite tricky to use.
Or another option is to contact Leon Harris if it doesn't fit properly to get it lined up.
Debbie
Posts: 5846 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
Agree with Debbie on the acetone or as I suggested to someone a few weeks ago the 3M adhesive remover. just dont get it anywhere else!
You'd be surprised some of the excuses I've heard from this. One guy brought me a watch and said he had tried to waterproof it It was a 21j BS in great condition!
Posts: 379 | Location: Charlotte, North Carolina in the USA | Registered: August 10, 2012
Also in Practical watch repairing by Donald de Carle he states that some watchmakers after servicing a watch would glue the case shut because it is very easy for dust to get into the case, there was an experiment done long time ago where a watch was placed in a bucket if flour with the case properly shut and when taken out of the flour and the watchmakers (or whoever was doing the experiment) opened the case it was discovered that the movement was covered if flour. This is because with the changes in temperature the case expands or contracts when it expands there is a vacuum formed inside and air is sucked in and the opposite with a cooling in temp. So I thing to some extent glue might have helped to seal the watch but I don't know what they expected to do when they got the watch back in 5 years for another service.
Francesco
Posts: 226 | Location: Johannesburg, South Africa | Registered: November 19, 2012
I've heard of putting a slight trace of watch oil or grease on the threads to try to keep dust out but I wouldn't do it. I think more air moves in and out of the case through the winding stem than through the threads, anyway.
Posts: 149 | Location: Southern California in the USA | Registered: September 23, 2009
The watchmaker I sat with years ago used heavy grease on the stem to help prevent foreign intrusion. I don't recall him putting anything on the threads of the case though.
Bruce, if acetone doesn't work, lacquer thinner will. It cuts just about everything, and it dries with no residue. You've just got to be careful to only get it on the thread areas. An eye dropper would be perfect. Brad
Posts: 956 | Location: Wenatchee, Washington in the USA | Registered: December 14, 2010
