Peoria Watch Co under dial Images "Click" to Login or Register
IHC Member 1555
Hi All,
Presently doing some research on the History of Peoria Watch Co and their predecessors, I am in need of some under-dial photos of the dial plate if possibly and also of the inner surfaces of both the dial plate and back plate (this is between the plates were the train wheels go).
If possible I need these photos from both an earlier serial number movement around the #12,xxx range in both the Nickel plate & Gilt plate versions as well as photos of a late Serial number movement as well. This later movement would be ideal if it is in the mid #23,xxx serial range, if not slightly early will be fine, until I can find pictures of the later serial movements.
I know it is a big ask, but with a bit of luck I will be able to clear-up some detail on this company and its predecessors, thanks to all in advance
