  Illinois expert help on Illinois signed "General"Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 1610 |
 I have a Columbia grade 18s Illinois KWKS 11j watch. I can't find any info on the web, I can't find any info doing a search here and it is not in the Illinois book. There are two Generals in the Illinois book but I don't think this is either one of those. SN 187513  | ||
| IHC Member 1610 |
 dial  | |||
 A search turned this Grade: Columbia Private Label(s) in Run: Iowa Watch Company, Independent Watch Co. Fredonia, N.Y. Manufacturer: Illinois Manufacturer Location: Springfield, Illinois Movement Serial Number: 187513 Grade: Columbia Model: 1 Estimated Production Year: 1881 Run Quantity: 2,000 Total Production: 38,013 Size: 18s Jewels: 11j Movement Configuration: Either Movement Finish: Gilt Movement Setting: Key Plate: Full Plate Barrel: Going Train: Coarse Railroad Grade: No Dial Feet Locations: 16.5, 36.5, 53.0 Case Screw Locations: O-36.5, H-51.5 Mel  | ||||
| IHC Member 1610 |
 Hi Mel, Thank you very much for the info. That is all I could find out also. I am assuming it is a private label but I was hoping for some more information as to who it was made for etc... The other two listing for General Grant and The General and even General Reno are in the Illinois book but nothing on "General". Maybe this could be "The General" listed in the book with "The" removed? Thanks again Mel, Harry  | |||
| IHC Member 1555 |
 Hello Harry, Had a talk to Dad about these, he said that they were a private label in his opinion. He has a few here in Nickel 103 Grade 5th Pinion 17 Jewel watches. Serial numbers up in the 3xx,xxx, so they were not just in the lower grades Erin  | |||
| IHC Member 1610 |
 Thank you Erin and be sure to thank Bila for me also. That is interesting to learn that they were also in the higher grades also. Thanks again Erin, Harry  | |||
