  My 931.  What do you think?Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 1016 |
 this is one of the purchases I made the other day.  I think these are relatively hard to come by.  Needs some soaking of the dial and a lift spring.  Actually the entire case is kind of rough.  Seems to run well.  | ||
| IHC Member 1016 |
 movement  | |||
 Your 1899 vintage 931 is part of only 4,000 serial numbers assigned for productin of this model. Nice collectible! A little restoration can make it a winner.  | |||
 Mike, it looks like it has a broken regulator lever.  | ||||
| IHC Member 1016 |
 Yes it does look like that and I would like to know which parts watches would have interchangable parts.  I have never got into changing one either so would need a tutorial if it is difficult.  | |||
 Mike, if you need one of those regulator levers, I have one, e-mail me. It should be an easy replacement. Just remove the screw, and make sure there is a pin sticking up in the adjusting screw, for the hole end of the lever. Of course you have to remove the balance cock, so you don't break the staff.  | ||||
