Interesting watch caseGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1613 |
I ran across this the other day and thought it was interesting...It is a swing out 18 size sterling case with an odd crown..Has anyone seen one before..I hadn't so I thought I would ask you guys.. ![]() | ||
| IHC Member 1613 |
Top part screws off to wind.. ![]() | |||
| IHC Member 1613 |
It is a swing out sterling case it a female winding stem..You could also put a male stem in it because the crown does lift up but is odd because it is spring loaded.. ![]() | |||
| IHC Member 1613 |
A shot of the back.. ![]() | |||
As you say, it is an interesting case. From the serial number I would say it was very early and probably a "transitional" case when watch co. were going from KWKS watches to Stem-wind watches. I have seen these with a plain KW type unknurled cap that one removed to wind a transitional movement, yours appears to have had a knurled cap which is greatly worn down due to the soft silver content. I suspect that a lot of these caps were in fact knurled to help one unscrew that cap. Very nice, I can't quite make out the case maker, looks like "_&_ Co." As with the main components of a watch, there are probably "case collectors" that would love to have that case !! regards, bb | ||||
| IHC Member 1613 |
Buster case maker is A.W.Co... | |||
| IHC Member 1736 |
That's not too far off how a modern waterproof dive watch stem works. I wonder if it was an early effort in the direction of dust proofing. Is that a patent number above the makers mark? | |||
| IHC Member 1613 |
Paul the Pat'd is Apr 22, 1878 or 79 can't make it out clearly..The odd part is the stem does lift up but does not have a sleeve so it doesn't stay..Rather it is spring loaded and as soon as you let it go the spring pulls it down..Enclosing another picture of the female stem.. ![]() | |||
An American Watch Co., Waltham model 1877-1879 should fit that American Watch case Co. lever set case with correct set lever slot and feel just as much "at home" as the first 1877-89 AWWCo., Waltham movement did! Similar to the below Model 79 American watch Co. Cased example that recently passed through my collection ![]() | |||
