18 size Waltham Vanguard - regulator question "Click" to Login or Register
18 size Vanguard model 1892
S#7449845
marked "21 Ruby jewels", Adjusted
diamond end stone
Arabic double sunk dial, very clean
keystone GF case, brassing and a couple of dings
S#2919341
what to check to have regulator centered
Posts: 535 | Location: Innisfil in Ontario, Canada | Registered: November 04, 2014
movement
movement 2
case back
case inside
Using a toothpick, rotate the teeth of the star wheel clockwise and the regulator arm will adjust back to center.
IHC Member 1291
Someone has possibly pushed the regulator to "slow" as it probably was running "fast" and needs a COA [clean/oil/adjust]. A watch usually runs fast when it is getting low on oil. That's usually...
David may have answered your question, I was wondering if that's what you meant or not. Its not a good idea to run a watch if its in need of a cleaning.
Buster's advice is very important. I do not recommend you run it for any extended period unless you know the service history includes a rece3nt cleaning.
David, Buster, thank you for responding. Actually the watch has been in for a clean/oil, I'm not sure about the adjust though. It has been about 3 weeks since the service and it has not lost or gained a minute at all.
To be honest it simply did not register that the regulator was off center that much until the other day. I had read since that a fix may involve a hairspring adjustment or weight adjustments.
Rick
Rick, that adjustment means little to nothing on the long run. Usually the micro-adjust helps "bring in" the last couple of position errors if they are affected by gravity on the hairspring. (Yes that IS an error cause.)
Thank you David, greatly appreciated.
You may have noticed I had two posts virtually the same. My granddaughters were helping, did not know what happened to the first post so posted again.
Rick
Administrative Assistant
Picture of Dr. Debbie Irvine
Here is your first post…
one of my favourites, model 1892 Vanguard
…it is there, however, I have locked it in order to keep all information in the same topic.
Debbie
Smile
Posts: 5813 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
Dr. Irvine, once again, thank you
Rick
