Serial Numbers for 18 Size Rockford 3/4 Plate Model 5'sGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1555 |
Hi All, Doing some research on the Model 5 Rockford's as mentioned above in title, needing a lot more serial numbers and observations as they seem to be all over the place characteristics wise during their production. If possible and if you would like to contribute we need serial number, plate material; either gilt or nickel, jewel count (if you are sure, if not can you please supply clear photo), if they have micro regulator, center wheel guard on back plate ( this is the little plate that is held on by two screws over the center wheel arbor) and if it is marked "adjusted" or the like, and just one other observation if possible, and that is, whether they have a female or male winding stem . Thank you to All in advance for taking the time to look and post any data Erin | ||
I have #150386,nickel,15 jewel, micro regulator, no guard on center wheel, and it has a female winding pinion(stem), it is not marked adjusted. Ernie | ||||
| IHC Member 1555 |
Thank you very much Ernie for responding, I will add it to the database we are building for these Erin | |||
