Serial Numbers for 18 Size Rockford 3/4 Plate Model 5's "Click" to Login or Register
IHC Member 1555
posted October 04, 2019 20:52
Hi All,
Doing some research on the Model 5 Rockford's as mentioned above in title, needing a lot more serial numbers and observations as they seem to be all over the place characteristics wise during their production.
If possible and if you would like to contribute we need serial number, plate material; either gilt or nickel, jewel count (if you are sure, if not can you please supply clear photo), if they have micro regulator, center wheel guard on back plate ( this is the little plate that is held on by two screws over the center wheel arbor) and if it is marked "adjusted" or the like, and just one other observation if possible, and that is, whether they have a female or male winding stem .
Thank you to All in advance for taking the time to look and post any dataSmile
Erin
posted October 06, 2019 00:34
I have #150386,nickel,15 jewel, micro regulator, no guard on center wheel, and it has a female winding pinion(stem), it is not marked adjusted. Ernie
Posts: 42 | Location: Manitoba in Canada | Registered: December 05, 2014
IHC Member 1555
posted October 07, 2019 01:25
Thank you very much Ernie for responding, I will add it to the database we are building for theseSmile
Erin
