Waltham Vanguard Question "Click" to Login or Register
Certified Watchmaker
Picture of Chris Abell
posted September 28, 2005 20:36
I have just got 3 Waltham Vanguards, two of which are pictured below, Both are S16 23 jewels 5 position, both have diamond end stones sets, GJS plates same layout etc, but the regulator arrangment are totally different set up, one is 15 million the other 19 million ser Nos are both model 1908s?
posted September 28, 2005 20:37
posted September 28, 2005 22:03
I think you have one of each.Notice the different diameters of the crown wheels and the ratchet wheels.These parts will not interchange between the two models.
J Smith
Posts: 188 | Location: Warrenton, North Carolina U.S.A. | Registered: January 12, 2003
posted September 28, 2005 22:52
When you say "one of each" do you mean a 1899 & 1908?, if so I dont find a diamond end stone 1899,
or was this standard.
RR Watch Expert
Picture of Ed Ueberall
posted September 28, 2005 23:41
There are a couple of other differences. There are different clicks as well as different micrometer regulators. The Model 1899 uses the star wheel regulator while the Model 1908 uses the Figure 8 (I think it is called an Ohlson) regulator. However, the different regulators are NOT a way of telling the Models 1899 and 1908 apart.
Diamond end stones were found on the Model 1899 and the earlier Model 1908 Vanguards. Later, Waltham dropped them and went to sapphire or ruby caps. You can tell the sapphire caps (which are water white in color) from the diamond caps by the upper surface of the jewel. The diamond caps were faceted, while the sapphire ones are domed.
Ed Ueberall
IHC Member 34
The Escapement
posted September 28, 2005 23:48
SN 15,081,373 is a model 1899
SN 19,001,399 is a model 1908
Picture of Bernhard Schmidt
posted September 29, 2005 01:49
Hi!
Some info about Olof Olsson.
Olsson regulator
Regards!
Bernhard
Posts: 423 | Location: Västerås in Swedem | Registered: January 02, 2004
posted September 29, 2005 07:54
Thanks Gents,
That’s exactly what I was looking for, I was thrown by the photograph in Shugart showing a model 1899 identifying it as a 1908, I couldn’t figure out what was going on, I suppose I should invest in a few more books!.
