Railroad Grade and Railroad Approved Question "Click" to Login or Register
Picture of Larry Lamphier
I know this topic has been on here time and time again, but I just cannot find my answer and need help.
I have a customer asking me if I could tell him the difference between "Railroad Grade" and "Railroad Approved" watches.
I have all kinds of answers rolling around, but none of them seem quite right to be telling someone who really might not know, and I don't want to steer him wrong.
Is there any topic that I can send him a link to that might help him, and me?
Thanks.
Administrative Assistant
Picture of Dr. Debbie Irvine
Hello Larry,
We moved this into public view so you can link to it for your customer or anyone else.
This is a question that is often asked but seldom answered succinctly in a way everyone can understand. I hope this explanation will help, we begin by bringing into play not only the watch and all its features but the time-frame in which it was originally produced and sold along with the exacting Time Service Requirements that were in effect.
Into the 1920s being a Railroad APPROVED watch included the minimum of 5 positional adjustments, micro-metric regulator, double roller, steel escape wheel, breguet hairspring, a very legible dial and various other requirements. The watch also had to be made by a company still in business, a decade later in the 1930s a South-Bend or Hampden may no longer be on the list of approved watches because those companies were no longer in business. By the same token, on most US railroads they usually would only approved watches "Made in the USA" under the guise of parts not being readily available to repair and properly service those movements from other countries.
Simply stated not all Railroad GRADE Watches were Railroad APPROVED at the time they were made. Take the interesting example of a Hamilton Grade 992 during 1920s production. It is well known that very Hamilton 992 ever made was Railroad GRADE and that has to do with the quality of the watch movement. Conversely, the Hamilton 992 in Pendant-Set configuration would have been Railroad GRADE but not Railroad APPROVED because of the requirement for Lever-Set being part of Railroad Requirements durng the 1920s time frame which we are considering.
Put a fancy dial on a Lever-Set 992 and although passing all other requirements the dial would not live up to the Railroad APPROVED Requirements, a watch had to pass on every level, quality was not the only criteria.
Moving to another related watch, the Hamilton 993 which was a Hunter-Case movement. By the 1920s that movement which was Railroad GRADE would not be APPROVED due to being a Hunter configuration. And then consider the 993 being available in Pendant-Set which could not be APPROVED for yet another reason even though it was the same, exact quality and passed all the same standards and positional requirements at the factory that the 992 in Lever-Set did. It can be confusing but the rules were clear and they were usually followed with specificity.
We know there can be exceptions to the rules, for example Lindell fondly tells the story of how in 1942 at the height of World War II his Dad's then thirty year old South-Bend was accepted to enter Railroad Time Service. The time inspector tested and approved the watch due to wartime shortages and difficulties in obtaining new watches. It was 18-size and from a long out of business company but the inspector found it acceptable under the circumstances.
Hopefully this discussion will help in your explanation and spur additional comments.
Debbie
Smile
Posts: 5530 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
IHC Member 1291
The simplest answer that would apply is as follows;
RRG; Any watch made by manufacturers that met or exceeded railroad standards. Grades such as Ham 992, Vanguard, BWRaymond, etc,etc.
RRA; A list of watches each railroad company would approve if purchased by their employees. This list would change many times over the years.
Let me touch on one more definition;
RRStandards; A set of requirements to be accepted or approved by each railroad line outlined by a commission or board appointed by railroad companies.
For the most part, toward the start of the 1900 period a watch in railroad service had to meet the following requirements;
Be open faced size 18 or 16, minimum of 17 jewels, adjusted to at least 5 positions, keep time accurately to within a gain or loss of only 30 seconds a week, adjusted to temperature of 34 to 100 degrees Fahrenheit, have a double roller, steel escape wheel, lever-set, micro metric regulator, winding stem at 12 o'clock, grade name or number visible on back plate, use plain bold Arabic black numerals on a white dial, and have bold black hands.
As time passed rules and regulations would change and different railroad companies had slightly different wording but the meaning remained fairly the same. In 1893 some railroad companies were a bit vague about their regulations and some had none at all. There were over 500 different American railroad companies at that point in time and there were no nation wide rules, but after 1893 The General Railroad Timepiece Standards Commission was formed and started presenting new guidelines. 15 jewel watches were accepted by some railroad watch inspectors as late as early 1900.
IHC Member 1338
Hi Larry;
I have customers ask me that all the time. Debbie's explanation is correct, what I tell my customers is RR Approved meant that the company would ALLOW the watch to be carried on the railroad (ie approved)
I have a list of most APPROVED watches on my website, here it is:
RR Grade/Approved Pocketwatches
Tom Dunn...
TIME MACHINE
www.myrailroadwatch.com
Thank you everyone.
This is very much appreciated.
Picture of Jerry King
Great question, Larry.... & Great answers by all and is understandable by all....
Thanks, to each....
Well my customer was very impressed by the answers and was sure to email me and let me know to thank everyone for the great education on this topic.
Around 1910 they started classifying railroads by the amount of revenue of $1 million, through the years this figure increased but in 1910-11 $1mil was a large dollar figure.
Considering that around 1910 there was a number of class 1 railroads that probably was in the ballpark of 100 if not more. The most stringent standards would be found on the class 1 railroads and for the most part I doubt that we have 5-20% of the watch standards documents from these railroads.
There were a lot of 17j adj3p what were railroad approved even up to 1920's but I think from the late 1890's the min positional adjustment was 3 positions and you could add the min jewel count as 17 with a steel escape wheel and patent regulator, tough to make a call on the setting since some pendant sets were allowed up too the early 1900's but not much after that.
You could make a good case that a "railroad grade" watch would be any watch from the 1890's up to the depression that was had a 17j count, 16 or 18s, had a steel escape wheel and patent regulator as a level of manufacturing quality, without regards to it being open face or or hunter.
Up to or by the stock market crash more than a couple of watch companies had gone by the wayside. With the exception of some deviations during the WW2 shortage one could make the case after the late 20's any watch that was manufacturered to the level of 19j adj5p steel escape wheel with a patent regulator without regards to being pendant or lever set could be considered railroad grade. By this time hunters or 18s watches were not an issue since they had gone the way of the dinosaur.
In the end to me railroad grade means a watch that was made at a quality level that was equal to or better than the railroad approved watches that were being produced in the same time frame.
IHC Member 1338
That'a a good way to look at it Claude, and very simple. I like it.
Tom Dunn...
TIME MACHINE
I am sure that watches like the Hamilton 922 or the Elgin Hubbard grades in the 12s were so well made and adjusted that they could have easily have kept RR time, without a doubt they would never have been RR approved but the level of quality was there.
It also would have been hard to argue that an Elgin grade 351 Lord Elgin would not have been as good as a BWR or Father Time 21j.
So on those grades that were not RR approved for some reason or the other such as setting type, size, etc but were made at a quality level that was equal or exceeded the RR approved versions is an easy way to judge or call them RR grade.
IHC Member 163
Picture of Mark Cross
The same can be said about 12s watches made by Illinois, Claude.
They thought so highly of some of their 12s watches back in 1916, for example, they even priced the 21j 12s model 409 the exact same price as their Sangamo Special, according to parts books of the time.
The only two things going against the 409 was its size and being pendant set. Otherwise it ticked all the boxes for requiments to be a railroad APPROVED watch, including marked 5 adjustments. Even had a diamond end stone.
Regards! Mark
Posts: 3838 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
