Guess What it is. "Click" to Login or Register
IHC Member 1610
posted June 15, 2012 20:03
Any guesses what this might be? Yes I know what it is? Here is a few hints. Sorry Jon but you can't play as you already know.
1) It is a size 16.
2) I paid $75 for it.
3) The case does not fit it and I have no idea why they had it in this nice gold filled case but I'll take it.
4) I have never seen a dial like this one before on this brand of watch. You may have and i is a shame it is in such bad shape.
5) it is a 1905 - 1907.
After I seen how good you guys are I'll show the back.
IHC Member 1610
posted June 15, 2012 20:04
Front
IHC Member 1610
posted June 15, 2012 20:05
Back not that it will do you any good.
IHC Member 1610
posted June 15, 2012 20:07
Closeup of dial. If you can see it the lever is about 2 o'clock and the notch is about 1 o'clock.
What was he thinking?
IHC Member 1610
posted June 15, 2012 20:08
Let the fun begin!
posted June 15, 2012 20:46
Looks like a four post Hamilton dial.
960? Confused
Custom movement?
Steve
IHC Member 1610
posted June 15, 2012 21:09
Dang, dang, dang. Steve you are right. I don't know about the custom movement. But it is a 4 post Hamilton dial. I have never seen one un-signed before.
Here is the movement. It will probably end up being a parts movement for my running 960. Around all the screwheads it is very scratched up.
It does not run. The gears on the center wheel came un-screwed and I put a new mainspring in it but it still doesn't even try to move.
I will clean it and see if it tries to tick. If so I will try to fix it if not it will be a parts movement.
Thanks Steve you know your stuff.
IHC Member 1610
posted June 15, 2012 21:11
And a little better view.
Picture of Eugene Buffard
posted June 15, 2012 21:52
The gear on the center wheel should screw back on.
Posts: 3326 | Location: Illinois in the USA | Registered: July 06, 2010
IHC Member 1610
posted June 15, 2012 22:10
Hi Gene,
It did and I wound it up after installing a new mainspring and it would not tick. I put a little pressure on the center wheel (not much) to see if it would make anything move. Well the only thing that moved was the mainspring. It un-wound super fast. I don't know why it did that but I will clean it tonight to see if I can get a better look at it tomorrow.
Harry
posted June 15, 2012 22:37
Harry, you have a Lever set Hamilton 960. With only 3000 or so made of this much venerated Bridge model design these very rare and valuable watches deserve professional help before messing with Mainsprings, Safety Pinions and the general business of this watch.
IHC Member 1610
posted June 15, 2012 22:50
So David you think I ought to spend the money to save this one since it is so rare?
I started cleaning it and the third wheel has a bent tooth and the staff with the gear on it will not stay in. I was planning on using it for a parts watch it too much was wrong with it.
David I will stop and send it to someone to put it in running condition.
Thank you once again for your valuable advise,
Harry
posted June 15, 2012 22:53
Woot Woot - 960 has surfaced...
Big Grin
posted June 15, 2012 23:40
Nice find Harry!
Wish I could find a 960, working or not!
Steve
IHC Member 1610
posted June 16, 2012 00:32
Hi Steve,
How did you know the unmarked dial was a Hamilton? I have never ever seen that before. Of course you could fill a lot of books with stuff I have never seen before.
David I put the watch back together and it actually ticks now. It will not run under it's own power but before it did not do anything. The third wheel has a bent tooth and the shaft comes out so I measured the third wheel out of a 974 and they are the same just not as pretty.
I will send it off to a professional to get her running and put a pretty third wheel back in.
posted June 16, 2012 02:27
Harry,
The shape of the numbers and the position of the breaks looked like other broken four foot Hamilton dials, and double sunk usually means high grade.
Steve
IHC Member 1610
posted June 16, 2012 11:16
Boy your good. I will see what I can do with that dial but it looks like a basket case to me.
posted June 17, 2012 00:41
That dial could use the "L.Riddle" Treatment!
IHC Member 1610
posted June 17, 2012 12:16
That's for sure but I found out why it was unmarked. Some (less then intelligent) person ground the signature off!
Picture of Dan Carter
posted June 18, 2012 17:08
Hate to butt into the middle of a conversation, but I'll give you $75 for the movement Harry, and you can keep the case Wink. But seriously, as I am reading this and not wanting to pull it too far off topic, are all 960's rare? I know there are less pendant sets than lever sets, but these do seem to come up from time to time on some auctioning sites. I picked one up a while back for a bit more (ok, a lot more) than $75 and after getting it working again have not done much else with it. I might have to put it into a nice case and start carrying it Smile
IHC Member 1610
posted June 18, 2012 22:16
Hi Dan,
I now they are expensive and they do come up from time to time and the ones I see go for $400 to $800 depending on condition. As for the rarity her is a post that David Abbe posted above and he know far far far more than I will ever know.
quote:
"Harry, you have a Lever set Hamilton 960. With only 3000 or so made of this much venerated Bridge model design these very rare and valuable watches deserve professional help before messing with Mainsprings, Safety Pinions and the general business of this watch."
