Recently picked up another grade 150 lever set that is different than the others that I have. This one is marked "No 150" and has 5 Positions stamped on the barrel plate. This one is a typical 150>277 type conversion, pendant set to lever set with the original pendant set machining left behind.
Posts: 1788 | Location: Michigan in the USA | Registered: September 19, 2009
Shot of the dial, Roman font but in nice condition the movement was in a later replacement "Sturdy" gold case but I put it into a swing out case that is more time period correct,
