help with Hamilton dials "Click" to Login or Register
Can I please get some advise as to what movements and cases go with these dials First image is a 974 movement, s/n 1189405, 16s 17j. The second image has a 992B movement, s/n C40114--I am currently looking for a dial for it: and I have this Model 2 Wadsworth Quality 10 Karat case, s/n 0440079, PAT 5-22-26. Is this a good case for the 992B movement? Thanks, Mike
Mike
Block letters
Posts: 56 | Location: San Antonio, Texas in the USA | Registered: February 06, 2013
another dial-script lettering, what would be an appropriate movement for this dial? Would this be an OK dial on the 974?
Mike
script dial
This is the two tone case I plan on putting the 974 movement in--OK?
Mike
Back of two tone Philadelphia 25 year case
Mike
back
Picture of Larry Lamphier
Hi Mike,
This might help you a little.
Case and Dial info
Let me add that the Script dial in the Wadsworth case is to early for that case. I can't tell the year without looking at the serial number of the case, but if you study that link, you will see where Richard has explained that same thing to someone else on the script dial. That is VERY helpful information there.
Those dials are VERY hard to come by Mike. I am looking though!
Thanks Larry, I love the 950B I got from you. It has a Melamine dial--and due to its manufacturing date, should I not consider putting a porcelain dial on it??
Mike
What is the Serial number of the 950B Mike?
I don't think I would leave a melamine dial on a 950B if it wasn't the correct dial for it.
Larry-s/n of 950B is S9825
Mike
Is it OK to put a 1942 992B in a 1928 Wadsworth model 2 case?
Mike
IHC Vice President
Pitfalls Moderator
That depends on how strict you want to be about the period-correctness of watches in your collection, it's up to you as a collector to set that standard.
Now a Case 2 would be right for a 1942 vintage 992B, but if you are as picky as I am, a 1928 vintage case 2 (case #040000-050000) wouldn't do, because it isn't strictly period-correct. I'd want a case number in the H575000-H625000 range for it to be period-correct for 1942, according to the IHC Hamilton_Wadsworth Case Number Database.
Many collectors would settle for any Case 2 that has the patent date in the signature, which shows it isn't a postwar case (when the patent date was dropped) . . . a 1928-vintage Case 2 would meet that standard.
thanks Ed, I'll start looking for a case--and an older 992B movement.
Mike
Mike, that is a 1950 950B so the melamine dial is correct.
What case is it in, and what is the case number?
Also let me check if I have a 1942 #2 case in the correct range that Ed mentioned earlier, for your 992B. Maybe we can work something out if I do. I just may have one that I was saving for a 992B movement in that time period. I'll let you know.
Site Administrator
Picture of Phillip Sanchez
Mike, Hi, I have a perfect model 2 case # H66503 and a perfect # 536 RWS porcelain dial if you are interested, however before you contact me ascertain if you really want to put that much money into your 992b. Neither of these items are inexpensive.
philsanchez2020@gmail.com
I also have a perfect script dial if you are interested
Site Administrator
back
Site Administrator
#536 dial
Site Administrator
back of dial
Larry, the case for the 950B is s/n K375613. Sure, maybe we can work a trade on cases
Mike
OK, I'm going out for a bit, but I have to tell you, mine is not as nice as Phil's, and he has the "perfect" dial also.
That case is also period correct for the 950B,
