DIAL CLEANING QUESTIONS
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/3423907877
June 07, 2013, 13:08
Donald McElhaney
DOES ANYONE HAVE ANY EXPERIENCE OR KNOWHOW ABOUT CLEANING A GOLD METAL DIAL ON A SOUTH BEND 16 SIZE WATCH?
THANKS
June 07, 2013, 13:30
Andy Schwartz
https://ihc185.infopop.cc/eve/f...351041233#4351041233
June 07, 2013, 13:32
Don, metal dials finished with thin, unprotected gold or silver plating for early 20TH century US watchmakers all suffer easily from the corrsion of the copper-based substrate "telegraphing" through the decoratvie plating. Gently clean the dial wby hand in a solution of dish soap and warm water and if the dial remains "dirty" looking you either have to use it "as-is", find a better dial (hard for South Bends), or send it to International Dial Co. in Ohio who will re-plate it and print some sort of new numbers and the maker's Name on it for you.
June 07, 2013, 14:19
Jim Bielefeldt
I have done a few South Bend watches for a friend who had me send them to International dial company because the dials were is so poor a shape it was hard to read some of the numbers. One of the dials was a cream/golden color background that came off but left the numbers in place when he tried to clean it. So be careful if this is what you are describing.
I was pleasantly surprised how they came out. The numbers looked almost the same as the numbers that were visible before the work was done. This was the budget refinishing. I understand that they have a service for collectible watches that will make sure that everything is exactly as it was on the original.
I have a few Illinois 12s watches that I will be sending to them because of the work they did. But they are beyond saving and better a refinished dial than one that is half gone.
I also came across this post in the clock repair section. I have not tried the method, but I would be very careful when doing it. Perhaps try it on a spare dial that is already ruined if you have one.
June 07, 2013, 15:59
Donald,
Check out our Watch Repair Questions and Answers forum.
This subject has been discussed numerous times, you may find the best topic is here...
Click for the "Porcelain-Enamel Dial Cleaning" topic.
Scroll up and down, read every precaution.
I would urge you to begin with very mild cleaners, use nothing abrasive on a metal dial
June 07, 2013, 21:37
Donald McElhaney
Thanks to all for replying to my question about dials.
