I have a dial that is slightly loose. It is on the movement and in the case. This pocket is a 992E Hamilton in a #10 case and in great shape...I don't really want to take it apart to find out the problem; I'm deciding if I should return it to the seller. Could it be missing dial feet? Maybe the screws?The looseness is side to side;with the hands on it's hard to tell if it would be loose in an up and down direction also. Any thoughts?
Most likely it is loose from shipping IF you purchased from a credible seller. I say likely because many of us err on the side of caution when installing the dial.
The other and far less likely possibility is a "stuck on" dial with missing feet. If you can supply the movement number and picture showing the dial we can probably determine whether or not the dial is a proper one for the particular application.
That is because there are only a few dials that are right for a 992-Elinvar.
Posts: 10553 | Location: Northeastern Ohio in the USA | Registered: November 19, 2002
SS# 2623336 And Lindell, I think you ae right about missing rather than loose feet. Wouldn't loose feet only show an up/down movement? And I would guess that two feet would have to be missing for me to notice...?
That is a genuine, original porcelain-enamel dial that is entirely correct for the watch. Hour and minutes hands may be replacements but seconds looks right. That all helps when beginning to establish whether you have a correct original or a sadly altered item.
You are caught "between a rock and a hard place" in this situation. If you take it apart and find alterations, the nearly impossible burden of proof is on you. I would carefully drop out the movement hoping for the best but being ready for the worst.
I'm new to Hamilton's and have the #10 case for this same watch in front of me. The bow screw does not look gold. That just doesn't ring true to me,considering the quality of these cases. Am I right? The screw is tool-marked also-in case that matters...Thanks.
Compare the screw in your Model 10 to what you see in the Wadsworth Case Model 2 you see below, same "bar-over-crown" idea protected by the same 5-22-26 patents.
And yes, the screw should properly be steel...
Hi Marty, I agree with Lindell, screw should more than likely be steel. I am working on a Model #2 case now and have it apart. Take a look at the picture there is a gold colored sleeve that the screw goes through.
Posts: 296 | Location: Livingston, Tennessee USA | Registered: May 20, 2006
Thanks for the back-up info guys. I'm OK now-just new to Hamilton cases and they seemed too nice not to have a gold alloy screw. As long as I have original parts I'm happy!
