Hamilton 900 Gold Case? "Click" to Login or Register
This nice little 900 just came in,
Purdy "Swissy" bridge movement!
Goldy lookin case I gotta clean up when I am cleaning the movement . .
So what ime leading up to does this mean Solid Gold or rolled gold?
David,
That means it's not solid gold. Just gold filled to a greater amount than the usual 25 year case. In other words, a thick gold plate.
Posts: 94 | Location: Collinsville, Virginia in the USA | Registered: January 01, 2008
Actually probably a "gold filled" case as opposed to "plated" gold or "rolled" gold. The latter two were generally used on lesser quality cases resulting in thinner gold over the base metal.
Posts: 292 | Location: Vancouver, Washington, USA | Registered: May 19, 2005
12-Size Expert
Picture of Robert Schussel
These "permanent" cases were sometimes referred to as 30 year cases. I guess after 30 years they fiqured you would not be able to hold them to their claim.
Bob
Posts: 621 | Location: Vallejo, California U.S.A. | Registered: July 10, 2004
Excellent responses!
The easiest way I found to remember is that any reference to a warranty time period up to and including "Permanent" always means a Gold-Filled case.
The Hamilton 900 is a great watch, it will be interesting to see Dave's "after" pictures!
Remember, I still have that 900 "braille" movement" that is really hurting for a 12 size hunter case with no Bezel or Crystal. Anybody?
12-Size Expert
David
Hamilton never made a 12 size Hunter.Thus you will need another brand for a case.
Bob
Here's the watch dial and fitment diameter for the case.
Dial Closeup, beautiful embossed or ? gold material
A "perfect 900" movement! (not wound)
I was thinking of "sleeving" a 16 size, or re-boring a 12 size HC.
12-Size Expert
David
Are you sure the dial is a braille dial. It looks like a regular dial with the numbers removed.
Bob
Just out of curiosity I looked up the braille number system. Those don't match. That's a good catch.
Thank you Robert! Closer inspection reveals those are HOLES! Not Braille dots, so someone yanked the Gold numbers off an otherwise good dial! I guess I can go on a "Numbers quest", or look for another dial for this. The case probably went to the Gold Digging numbers yanker also. btw, I bet that was a solid gold case! Roll Eyes
