Movement shakes when case is shaken "Click" to Login or Register
IHC Member 935
posted August 29, 2007 17:40
What causes the movement to shake when the case is shaken? Could this be a movement in a wrong case, or did a watchmaker forget to do something?
Posts: 175 | Location: Davis, California USA | Registered: March 10, 2007
posted August 29, 2007 18:14
Could one or both of the case-screws be loose?
That often happens in shipping, take a very close look.
posted August 29, 2007 19:57
I agree with Lindell. The most common cause is a loose movement and loose case-screws.
But.... let me go a step further. IF, in fact, that is the situation, do NOT attempt to tighten the movement unless you have proper screwdrivers, properly sharpened and you have the experience to do so. Many, many of the worse movement scratches are caused during the casing process. Also, If the movement is tightened improperly, the movement can "walk" a bit as it tightens-down. This can cause the stem shaft to bind, making it difficult or impossible to wind or set the watch.
The seller might have had this problem and was not able to properly case the movement.... so he left it loose.
Caution! Eek
IHC Member 935
posted August 29, 2007 21:35
Thanks for the guidance, Lindell and Peter. The watch has stopped twice, although fully wound. I do not believe that the watch is one for me to have, and I am sending it back. I did not look for the case screws because I do not know where they are or what they look like. It's a South Bend 227 movement.
posted August 29, 2007 23:13
Might the movement need a dust ring to fit the case properly? I've had a couple of watches that didn't have dust rings and were loose when I put them in a case that were fine after I found a proper sized ring for them.
Norman
Posts: 153 | Location: Northeastern United States | Registered: December 18, 2005
posted August 30, 2007 00:45
My strength is in research. I love to read and learn about these wonderful artifacts. No one who knows me would let me put a tool to a watch or clock.
Chapter 52 has lots of friendly mechanicaly inclined members willing to share their expertise. If you are not a member of a local, consider joining one.
I always expect new purchases to need a bit of loving attention.
happy hunting,
Posts: 881 | Location: Arroyo Grande, California USA | Registered: February 22, 2004
posted August 30, 2007 10:36
We strongly urge all Chapter 185 Members to get involved in their nearby land-based chapters to the greatest extent possible, I for one an a supporting member of eight other chapters in addition to my Chapter 185 Membership. Although we try to provide a similar experience in our virtual chapter meeting, the in-person fellowship, friendships and other available services found at the local level are very worthwhile.
Back to the watch, since the movement is a South-Bend 227 take a close look at the similar South-Bend you see in the image below. You will notice the two case-screws (circled in red) are inserted into the movement and contact the edge of the case which holds the movement in place. On some watches and in certain circumstances a dust ring can be important to proper fit but I do not feel that is the basic problem on this one.
If the case-screws are indeed loose it should be readily apparent upon close examination. That is the first step, to diagnose exactly what has happened in this instance. Begin with the most likely situation and move forward by process of elimination. Peter's suggestions are very good, but let's first see if the case-screws are loose. Once we know that answer one way or the other we can either tighten them of move to the next possibility.
Look to see if the case-screws are seated like these...
posted August 30, 2007 13:00
My concern and my hesitancy are based upon the fact that loose case screws ARE so obvious and the repair appears so simple that just about anyone would think it easy to do. After all, who has not tightened a screw?
I took two full days to service my first pocket watch.... practicing on a "junk" watch at each stage until I had the confidence to work on "my" watch. When the movement was finished and running to factory-specs, I cased it and ... scratched the movement. Those case screws are slippery.
The lesson of using wrong-sized screwdrivers ... scratched the movement.
The lesson of using unsharpened screwdrivers ... scratched the movement.
I learned some lessons the hard way. I'd love to see someone else avoid that particular learning process.
Certified Watchmaker
Picture of Chris Abell
posted August 30, 2007 14:35
I Have found often that the loose movement is due to the screws having been over tightened previously and are often to be found screwed tight on the movement. With the case lip being gouged away or the lip of the case edge is bent below the plates and out of reach of the screw heads, an easy fix once you see the problem.
IHC Member 163
Picture of Mark Cross
posted August 30, 2007 15:37
Gee, Chris, I wonder who you know who's done such a thing to a watch? Confused Wink
HIGH regards! Mark
Posts: 3838 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
IHC Member 935
posted August 30, 2007 16:37
Thanks everyone for the education that you have given to me. I have sent the watch back to the dealer for a full refund. Several times, the watch stopped running. The dial is not the railroad dial that I had ordered, but some kind of art deco style. The dealer had, without first telling me, substituted this model for one he had offered, which had railroad dial, but he said that he had already sold it. I am now searching for the railroad dial version. Lindell, that photo showing where the screws are located is just perfect!
IHC Member 163
posted August 30, 2007 17:16
He substituted watches without TELLING YOU?!! Eek
That's grounds enough to send back REGARDLESS of the loose movement. Mad
Regards! Mark
posted August 30, 2007 18:07
You got that right Mark!
I can think of something else loose about that seller. Roll Eyes
"Just Walk Away Renee!"
IHC Member 163
posted August 30, 2007 18:39
In returning to our regular programming ( sorry about that ) of which I kind of derailed, the 'individual' I was referring to in my response to Chris Abell was myself.
I've sent him a couple watches in the past year that he has asked if I had put the movement screws in with a jack hammer. Frown
I have since learned from our good friend Mr. Abell that you do not 'ham hand' a movement screw into a case. Too tight a screw can also warp a movement plate, ALSO causing the watch to stop.
Yep, I'm learning a lot from my friend Mr. Abell, even if it's by email. Thanks again Chris!! Smile
HIGH regards! Mark
