Question on time setting method of old ElginGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hello All, I have a 1900 Elgin, 18S, 15J, Grd.218, Ser.# 9226237. In order to set the hands, you must turn a screw located at the back of the watch, 1/4 turn left, set hands, then turn right 1/4 turn to lock. The screw is located just below the mounting screw located at the 2 o'clock position. Can anyone shed some light on this unusual time setting method? It's a new one on me. Wasn't able to send a picture, Sorry. Thanks, Don | |||
Hi Don, according to your ser# the watch should be a pendant set watch, so can not help with the method you describe. I am sure some else here will be able to shed some light on it though. Bill | ||||
| IHC Member 163 |
Just to toss this out there....this sounds just like the way the pendent set Hamilton 950's were made in order to meet railroad requirements of being 'lever set' or non-stem set. They had the screw in the back that you could set the watch with, then once the screw was turned back to position, you couldn't use the stem to re-set the watch. It met railroad requirements of the time regarding non-pendent set watches. Never heard of an Elgin that did this, though. Regards! Mark | |||
Thanks for the response guys. Don | ||||
| IHC Member 1291 |
I am not real familiar with Elgin, but What it sounds like you are describing was a screw for the watchmaker to transition between winding/setting positions while working on the watch with it uncased. A few watches were made with a screw that had a "P" or a "L" engraved on the plate, which you could turn the screw and make it pendant set or lever set. But I don't think there was ever a watch that you had to carry a screwdriver around with in order to set the time. regards, bb | |||
Hi Buster, You are correct. With the screw turned 1/4 turn to the left and kept there, the watch can now be pendant set and you can still wind the watch. Thanks for solving the mystery. Regards, Don | ||||
