Curious if this is US or Swiss or ?: "Newport" marked movementGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Ok - I would like to offer this for sale on IHC; however, cannot find any information on the movement. So, as to avoid incorrectly describing the watch. Would like to tap the vast knowledge base here 1st. I would "think" the movement was made in the States since the case is Canton, Ohio (Dueber), BUT, a Newport movement is sort of Greek to me. KS/KW The case is 2.1 inches straight across. Serial # is 81409 At least an eleven (11) movement Movement and dial both stamped "Newport" Case is stamped "Dueber Newport Coin" (90% Silver 2 oz) Has the old school hairspring that is fastened to the movement plate, but the pressed in plate jewels are throwing me off a little. Thanks in advance | |||
2 | ||||
Cool case! | ||||
Jon, It's Swiss. That barrel bridge form is fairly common with a variety of names on the movement. The "engraving" on the balance cock is typical for low grade Swiss movements. Kevin | ||||
Killer case!!!! | ||||
Thanks Kevin I love the case too. Just seems odd to me that a swiss movement stamped Newport would be married up with a case made in the States that is stamped Newport, too. | ||||
Maybe a local jeweler in Newport Kentucky, where the case was made had the movement personalized???? | ||||
| IHC Member 1555 |
Definately Swiis Jon, gilding type colour and serial font points to this also, as well as the un-compensated balance. Cheers, Bila | |||
