E.Howard series IVGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Here is my E.Howard Series IV I recased nice case it fit like a glove the next thing I need to do is clean up the dial I saw a post here on cleaning up dial's that mite work and then this watch mite look mint. | |||
Beautiful watch and case. Since "N" size is a bit large than 18S did you have to modify your case? | |||
| IHC Member 179 E. Howard Expert |
A common misconception on the Nsz Howard is that the Howard movement is larger than a normal 18sz watch. That is only partially true however, the pillar(dial)plate is a bit larger than an 18sz, 46.05mm compared to 44.86mm, but the back plate measures out a bit smaller in diameter compared to a conventional 18sz. That is why many of the re-cased Howards show a bit of a gap between the movement and the case..... Just a little worthless Howard trivia....... Harold | |||
Had to modify it a little but this case was so close it all most fit. | ||||
