I will first post a first run grade 349 that I picked up recently and you should be able to notice the basic differences. This should have been a run of 500 then the runs fell into the typical 1000 type runs. The dial is a psuedo double sunk replacement type dial that I put on while I find the correct type for it. It was in a crapped out case and I found this one to put it in, even though it low year case it looks extremely nice and has not seen much use. Front View ![]() View with bezel open ![]() Label-still in case ![]() Movement ![]() Case Back ![]() Case Edging ![]() | |||
Here is the more typical Grade 349 with the exception that this one is marked "Adjusted 5 Positions" ![]() | ||||
Here is the much more uncommon version "Father Time" grade 349 also marked "5 Positions" ![]() | ||||
Father Time | ||||
Nice heavy Petina Sterling Silver Case | ||||
Father Time - 266 ![]() ![]() | ||||
Father Time - 252 ![]() ![]() | ||||
Father Time - Grade 391 ![]() ![]() ![]() | ||||
Father Time - Grade 995 Hunter ![]() ![]() | ||||
Father Time - 375 ![]() ![]() | ||||
IHC Life Member Wristwatch Host ![]() |
Claude, Thanks for the pics of the 21 jewel Elgins. I will be looking for some of the Elgins to add to my collection. Again thanks for the pics and info. Tony | |||
Tony there are times that people post pictures of brands/grades that normally I would not look for but after seeing the pictures I do start to look for them. So that is why I like it when people post pictures and the reason I post them. There are some interesting Father Time variations, some that are very low production but beautiful watches. I need to take some pictures of my other Father Time grades and post them. | ||||
