This Bow goes to what RR case ? pic includedGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Measures 19.43 mm from end to end Thanks | |||
They looks to be for a Hamilton 892, Swiss made with a 17 jewels Unitas movement. Regards, Krister. | |||
Krister, They actually fit on the BOC 16sz Hamilton case too. I wonder if I guy had a brassed out tube on the BOC case and just used the tube off these, and kept the original bow. Thanks... | ||||
These bows were marketed by S. Larose and others as replacement bows for the Bar O Crown cases. I believe the tubes "could" be used on the regular screws on the original bows, but they are a bit long and a hair larger diameter tube than the originals. They can be ground/sanded/cut down for the correct length but the diameter is going to always be there and they are going to be a bit big and fairly easy to tell + they may rub a bit on the top of the crown. regards, bb | ||||
Buster, You are correct the tubes are a hair too long. However, with a light and gentle sanding they do work. I will have to dig around, I remember seeing one of them on a BOC case as a replacement... | ||||
You can buy all you want from JBorel. Part # 176-60 Regards, Larry | |||
