  Help with a Illinois watch.Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
 I collect Hamilton 992's. So any information about this Illinois will help. Do the hands, case and dial look correct? Any information on the year of production would also help. Thank's for any help or information. Bernie Babauta ![]()  | |||
 more pics. ![]()  | ||||
 one more ![]()  | ||||
 back ![]()  | ||||
 inside cover ![]()  | ||||
 better pic ![]()  | ||||
 Good evening and welcome to IHC185 If I have read the serial number correctly i.e. 5510722, then the following information from the pocket watch database would appear to apply. Grade: 161A Type IIB 60hr. Elinvar. Movement Serial Number: 5510722 Estimated Production Year: 1932 Run Quantity: 2,000 Size: 16s Jewels: 21j Movement Configuration: Openface Movement Finish: Nickel Model: 15 Movement Setting: Lever Plate: 3/4 Plate Double Roller: Yes Barrel: 60-Hr. Motor Adjusted: Yes Adjusted to Positions: 6 Adjusted to Temperature: Yes Railroad Grade: Yes Notes: Type IIB 60hr. Elinvar. Those folks with access to the Illinois records will be able to confirm or deny these findings. Regards David  | ||||
 Bernadino, as a Hamilton collector you will find many kindred spirits in IHC185. Our many resources of parts, service and research will reward you many times over our $12.00 registration maintenance fee. Your Illinois Bunn Special 161A watch was among the last made in 1932 at the Springfield Illinois factory. By 1933 management was moved under the direct control of Hamilton Watch Co. personnel. So your Illinois 161A Bunn Special s/n5510722 is a "crossover" piece that connects your selected collection of Hamilton work to some of the finest pocket watches made in USA which also were the first to manufacture high accuracy and production 60 hour movements. Your 161A variant enjoyed production of only a few over 5500 movements included the 1790 piece run that yours was in. The case is a Bunn Special, but has me puzzled a little bit with the Bow design. Could Be a service replacement.  | |||
| IHC Member 1016 |
 I'm not an expert but I think it looks like a very nice watch.  The bow looks correct but possibly worn.  Am I missing something here?  | |||
| IHC Member 1101 Site Moderator  |
 I can't read everything in the case back but the serial number seems to be in the range of a 1928 production Bunn First Model case. Also the hands look to be plum colored and if they are I believe the watch year of 1932 is well into the blue hands. Stev  | |||
| IHC Member 1338 |
 I think 1931 was the last year for the 1st model case, wasn't it? I'm seeing a Model 29 case on most of these 161 series of this vintage If you look in the Illinois section here, I believe you'll find most or all of the info you're searching for.  | |||
