  Rare 16 size Waltham Railroader variation (Images added)Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
 16 size Waltham model 1888 (Riverside grade) marked Oregon short line. I can't find any information on this run/special order. ![]()  | |||
 The damaskeening is like that of the Railroader or Roadmaster models. Diamond cap jewel, gold center wheel, double roller, yet pendant set. ![]()  | ||||
 The imitation double sunk dial is one I haven't seen before save for one I observed on another 1888 model. Hands are like what are found on earlier 18 size model 1892 models. ![]()  | ||||
 Serial Number?  | ||||
 7,103,649. Photos to be posted soon.  | ||||
| IHC Vice President Pitfalls Moderator IHC Life Member  |
 Here's what the online pocket watch database gives for that movement number: Grade: Riverside Movement Serial Number:7103649 Estimated Production Year: 1897 Run Quantity: 1000 Size: 16s Jewels: 17j Movement Configuration: Openface Model: 1888 Movement Setting: Pendant Plate: 3/4 Plate Adjusted: Yes Best Regards, Ed  | |||
| IHC Member 1613 |
 William very nice watch...Here is a couple of pictures of my 16 size Railroader..Serial number 6,506,622..Also a pendent set movement...  | |||
| IHC Member 1613 |
 Pic #1 ![]()  | |||
| IHC Member 1613 |
 Pic #2 ![]()  | |||
 Very nice Gary, looks like yours has a correct dial. Here's what the online database says about it: Grade: Riverside Movement Serial Number:6506622 Estimated Production Year: 1898 Run Quantity: 144 Size: 16s Jewels: 17j Movement Configuration: Openface Model: 1888 Movement Setting: Key Plate: 3/4 Plate Adjusted: Yes Obviously the movement setting needs to be corrected. Best Regards, Ed  | |||
 I'm hoping to find out who may have ordered this run of so marked movements. I certainly know how to find the factory production figures of the basic model and grade.  Apparently this watch just isn't that interesting  | ||||
| IHC Member 1110 |
 Nice rare Waltham!I'm surprised it is pendant-set, although come to think of it,'88 models usually are.Did they even make '88's in lever setting? Has it ever been figured out as to who those Railroader and Roadmaster models were made for?I've always heard they were private label.Thank you, Ted.  | |||
 William, according to the highly respected Ehrhardt Meggars "Gold Book, this is among the most valuable Model 1888 Waltham watch models made . . . EVER. With that dial Ehrhardt shows $1000.00 in the early 1980's I suggest you insure it for about three times that minimum! ![]()  | |||
 Yes, the older Waltham material catalogs that listed material for the 16 size 1888 model showed a lever-set type setting lever. Never having seen such a movement live and in person I don't know if or how the Swiss type detent stem and detent lever and combination clutch lever and spring would have been modified to have the movement become lever setting.  | ||||
 I'm putting the watch on ebay tonight to see what happens. I have a B.I.N. price of $1,000. (Watch doesn't fit into my collection but it was a pleasure to see it restored).  | ||||
 Sorry, "My Bad", I was referring to Gary Cochran's watch with the Railroader dial. The "Oregon Short Line" fitted with a Diamond cap jewel and with the same surface Damaskeening as the Railroader may be of equal value to a Knowledgeable collector.  | |||
