clapping threw the timing off? "Click" to Login or Register
I've been wearing a lady Elgin (grade 447, 10/0s) I cleaned and repaired for about a week now. It was running about a minute fast per day, and I want to work on it some more, but I was enjoying looking down at my wrist knowing I had brought her back to life.
I went to the Joffrey Ballet the other day, wearing the old girl, and after a rousing performance and five minutes of clapping, she runs fast by five minutes a day now.
What happened? I am on spring break now and have time to work on it, so what is it I should be looking at? I haven't taken a look yet.
Posts: 152 | Location: Miami, Florida in the USA | Registered: August 11, 2009
Picture of Roland Glenn
Hi Dale. Check to see if the hairspring jumped out of the collet and is now one more radius inwards attached. Also, did any timing screws come loose from the balance?
That gets you started.
Roland.
R. Glenn
By Collet I mean the two pins that are attached to the regulator that the hairsprings outer most coil slides through when the watch balance is in motion.
Not sure what those pins are properly called, but their in the image shown below.
Roland.
R. Glenn
Roland, they're called 'Curb Pins' Smile
John
Thank you John, much appreciated and I now have learned a new parts term.
Roland.
R. Glenn
Great. Thanks. I'll take a look.
I took a look at the hairspring and it looked fine, so I put the balance back into the watch and it just wouldn't run again. I fiddled with it and it will run if it is dial side up, but when I move it around it stops.
I am going to take the balance apart and true and poise it.
I'm thinking that should fix it. Any other opinions would be welcome.
Thank you. I will check all of that.
I appreciate all the help.
