Is there any trick to removing the above described movement from an original ball case?
The stem is not wanting to leave the movement. Don't want to damage, bend or break anything. Crown pulls up in theory to give you less stem in the movement, but still acting like it is attached. This is not like one of the 16s 21j newer elgins with the "lock screw" that holds the stem in?
Posts: 7178 | Location: Illinois in the USA | Registered: November 11, 2011
Jon is there a small screw next to the crown wheel? If there is turn it counter clockwise until it stops and then lift up on the stem. Early Hamiltons had a screw that locked the stem in but I know nothing about Ball.
Posts: 3850 | Location: Georgia in the USA | Registered: September 22, 2011
