Help with ID & value "Click" to Login or Register
Picture of Patrick Wallin
Defiantly a Military time piece with no ID Marking other than Military inscribing on the back of the case. At the bottom of the dial it says "Swiss Made"
It's a 16 s in a very heavy case. 3.1 OZ. I have not opened the case yet. It has a set screw to tighten or loosen the movement of the Bow. I can't see any method of snapping the case apart but at the same time I can not get it to screw off either, The unit works perfectly every time you push the stem.
Back side
Back side again
It´s an 10 second stopwatch, type A8, exactly as it says on the back, made by/for Wakmann watch Co.
MIL-W-6510-WATCH, STOP, NAVIGATION, TYPE A8
Posts: 699 | Location: Hannover in Germany | Registered: July 23, 2009
Moderator
Picture of Donald Trumble
Lindell tells us about his Waltham A-8 here...
Waltham Military Timepieces
And in this topic, Dave Abbe shows three A-8 versions...
A8 Military Stopwatch Question
Hope that is of help.
Don
Posts: 504 | Location: Pennsylvania in the USA | Registered: April 02, 2005
The Waltham A-8 timers that are in the linked threads are older ones - generally WW 2 era. Your Wakmann is a more recent one.
As for value you see prices for these all over the place, but in general they do not go for very much, even the older Walthams and Elgins.
Posts: 875 | Location: Baltimore, Maryland USA | Registered: September 20, 2004
Hello Patrick,
Here is another great link to a topic related to your A8. Jim gives a great explaination of its use in the field. It also shows another earlier example by Waltham. Regards, Mike
https://ihc185.infopop.cc/eve/f...0103944/m/3443956557
Posts: 497 | Location: Southcoast Massachusetts | Registered: May 13, 2010
