Hamilton 33106 questions "Click" to Login or Register
I have a Hamilton watch and am trying to find out more information on it. I have read many of the posts on this and other forums and have learned a lot but still have questions.
My watch has the following on the outside back of the case:
AN 5740
STOCK NUMBER (blank)
MFR'S PART NO 33106
CONTRACT NUMBER
DA-36-038-ORD-9702
SERIAL NO. AF-52-6051
HAMILTON WATCH CO
Inside the back of the case is the following:
KEYSTONE (in a banner)
Base Metal
K0940054 (in a semi-circle)
There is a hand scratched number that starts with: 94A and then becomes illegible. There is also a handwritten number in pencil that I cannot read.
The markings on the movement are:
HAMILTON
WATCH CO.
U.S.A.
4992b
22
JEWELS
ADJ TEMP
AND 6
POSITIONS
4C103288
There are no government markings on the movement.
The face appears to be the same as the “standard” faces I’ve seen on the internet: black face with white lettering, white hands, 24 hour markings with second markings on the outer ring and “G.C.T” in the center.
My questions are:
What is the difference between the 33106 and other watches?
Does the fact that the movement is marked 4992b and the case carries the manufacture part number 33106 indicate the movement and case have been switched at some point?
Does the Government s/n “ AF-52-6051” indicate purchase by the government in 1952 as some forums suggest?
Using the serial number lookup table on NAWCC Chapter 149’s website, the suggested production date is 1943, is this an error?
Does anyone have any suggestions on an appraiser or technician who can appraise and clean the watch in either the Kansas City area or the New Hampshire seacoast region?
The overall condition seems fairly good to me. The crystal is very clear and appears to be plastic; the case has a few dings but is bright and shiny except for the back, which is mostly worn down to a brass colored metal.
Any other information would be greatly appreciated.
Thanks in advance
Sandy Walker
Posts: 2 | Location: Missouri in the USA | Registered: January 05, 2010
Site Moderator
Picture of John J. Flahive III
Hi Sandy,
You have a high grade and very collectable Hamilton 4992B military pocket watch.
Your watch is a perfectly normal example as far as I can tell based on your excellent detailed description. The manufacturer's part number of 33106 on the back on the watch is part of the ordnance markings which should not be confused with the grade 4992B. Some other on this forum may be able to tell you more about these markings or you can look them up in a book on military watches.
Great watch overall. Post some pictures if you can.
John
Posts: 1755 | Location: Colorado in the USA | Registered: October 17, 2005
Sergeant at Arms
Picture of Scott A. Whittey
Aloha Sandy
Q. What is the difference between the 33106 and other watches? A. The Part # 33106 Is for the complete Assembly. Case, Movement,Dial and hands.
Movement-Model 4992B = Military PN 33005
Dial- PN 50-079
Hands - Hour -- PN 33042
" - Minute-- PN 33043
" - Second-- PN 33044
Case-PN 33051
Assembly Unit Part 33106
Q. Does the fact that the movement is marked 4992b and the case carries the manufacture part number 33106 indicate the movement and case have been switched at some point? A. Yes and No. That is to say it may have been switched at depot level maintenance. It does not mean that it is not correct
Q. Does the Government s/n “ AF-52-6051” indicate purchase by the government in 1952 as some forums suggest? A. AF-52 indicates a 1952 contract
Q. Using the serial number look up table on another website, the suggested production date is 1943, is this an error? A. I would say yes
Q. Does anyone have any suggestions on an appraiser or technician who can appraise and clean the watch in either the Kansas City area or the New Hampshire seacoast region? A. I send my 4992Bs to Chris Abell in Texas for maintenance
http://www.abellwatchmakers.com/
Aloha Scott
Posts: 293 | Location: California City, California USA | Registered: May 05, 2005
The AF-52-6051 serial number is saying that the contract from the Air Force was issued in 1952, however it may have been manufactured and delivered in 1952, or 1953, or 1954, or even later. 1952 is the earliest the watch would have been manufactured and delivered, but depending on how the contract was negotiated they may have had several years afterwards to make and deliver the watches under this particular contract.
If the movement's serial number dates it to 1943, I agree that one possibility is the serial number reference you are reading has errors, but the simpler explanation is the movement and the case do not belong together and are a marriage. Such a marriage could have happened while the watch was in the hands of the Air Force and some Air Force timepiece repair station might have put the movement into this case to make a working timepiece, or it could have been done any time after it left the hands of the Air Force up to the day before you purchased it. There are large numbers of movements with badly damaged cases and cases with badly damaged movements, and just plain orphaned movements and cases and dials and such from many military timepieces in the stocks and storerooms and dusty back shelves of old time watchmakers. With the recent rise in interest in military timepieces, many of these parts are being dusted off and married up into timepieces to sell them.
Posts: 872 | Location: Baltimore, Maryland USA | Registered: September 20, 2004
Hello Sanford,
Adding to John, Scott and Jim's observations, perhaps these comparisons might help.
In my collection I have movement number 4C12417 from 1942 and 4C68081 is verified as being from 1943 and now consider number 4C102970 which is from 1945 production, right at the end of WWII and below your number. Right there one would reasonably question the information you found elsewhere on that website. That is the problem with "guesstimates" as I tend to call them. Anyhow from those 1942-45 numbers you can see it would be reasonable to say your number 4C103288 is clearly a post-WWII example. You will also want to compare your SERIAL NO. AF-52-6051 to other early 1950s examples, it may well turn out to be an original combination.
Now let us move forward to number 4C134785 which was part of a 1959 contract and puts yours into context further. Recently another apparently original watch from that same 1959 contract, movement number 4C133981 sold right here by Barry Hanstein in the IHC185 Items for Sale, here is a link... Hamilton 22j 4992B GCT Military PW I suggest you will find my comparisons of those two watches of interest as I previously suggested comparing yours with others that appear to be contemporary to it. Since you are not as yet an IHC185 Member (Click to Join and Support IHC185 for only $12.00 annually, you will agree it is the best $12.00 you will ever spend!) here is a quote from that topic...
____________________________________________
"On the case-back that "AF-59" followed by the number 20636 is important, that means Air Force and a 1959 contract. For comparison I have movement number 4C134785 with AF-59 21799 on the case-back. Notice both numbers are just a bit higher that Barry's watch. Taking it further, Barry's Star Case is P114822 and mine is housed in P116549 so again the numbers fall into place perfectly. These two watches are part of the same contract number and would seem to verify each other as to authenticity and originality. Smile I love it! "
Two more points, movement number 4C139516 is the highest number complete 4992B that I am aware of, it is clearly later than the "AF-59" examples I cited and the Serial Number 25432 may turn out to be a continuum from the 1959 contract numbers quoted above. It also carries "U.S.A.F" markings on the case-back but no specifications about a contract date. And then, be sure to look through this topic... ""Evolution Of 4992B and 3992B Numbers / Database Beginnings" a two page project coordinated by Scott Whittey, IHC Life Member and Sergeant at Arms.
There, the numbers really begin coming together, some of them dance like Fred Astaire and Ginger Rogers at their best.
As we continue to assemble more numbers it may be possible to date the 4992B watches a bit more closely.
Hope at least some of this is of help to you and to the record.
Lindell,
I beieve Sandy's example matches perfectly. This example currently on eBay, predates the example that Sandy has, both in movement serial number and watch serial number: Hamilton G-4992B serial number 4C102548, serial number AF-52-2169.
Some other numbers for you:
I have in my collection, Hamilton G-4992B with serial number 4C128149 in a case with serial number AF-58-13127, no inner caseback serial number.
This one just sold on eBay: serial number 4C120913 in a case with serial number AF-58-7712, inner caseback serial number R828672. These two matche the timeline very nicely.
Another to add to the record that sold recently: 4C102809, AF-56-818 and 4C131884, AF-59-18476.
These have relatively high serial numbers:
Hamilton G-4992B serial number 4C142944 on eBay currently, with inner case serial number of P118695. Caseback has been polished unfortunately.
Hamilton G-4992B serial number 4C143017 also on eBay, with inner case serial number of P118761. Non-typical (at least to me) case back with Stock # DAAA25-67-C0565.
Best,
James D.
Posts: 101 | Location: San Antonio, Texas in the USA  | Registered: July 25, 2006
Thank you everyone who has replied; I have enjoyed learning more about my watch.
Sandy Walker
I have one. Finally found this forum. Will try to post some pics. Mfr's part # 33106
Posts: 1 | Location: Seattle, Washington in the USA | Registered: October 03, 2013
