Elgin WW2 Aircraft clock
https://ihc185.infopop.cc/eve/forums/a/tpc/f/990103944/m/42710772
February 21, 2009, 22:16
Mike Sandell
Here is my elgin A-11 aircraft clock and thanks to David giving me a needed part this would not be a working clock.
February 22, 2009, 09:20
Jim Hester
I really like these A-11 aircraft panel clocks. All of the makers of them during the war really built them to last. Could you post a photo of the data plate on the back of its case?
February 22, 2009, 15:50
Mike Sandell
Jim the plate is missing from the back.
February 23, 2009, 10:40
Roger J. Nolfe
I really like the 8-day clocks made by Elgin and Waltham. They had 2 big mainsprings. Even if one breaks the clock will still run.
Roger
August 21, 2014, 13:32
Tim Wells
Actually they only had one mainspring in the Waltham A-11 as well as the Elgin with mostly the 562 grade movement. The only A-11 I know of with 2 mainspring barrels is a Wittnauer.
I've overhauled all the US ones of that era and the Wittnauer is my favorite due to its rugged movement. The Lemania's that are in so many planes are my least favorite as the escape wheel pivots are way to fragile for the application.
August 05, 2024, 17:22
Thomas Snyder
I recently acquired one of these clocks. I am able to wind it. But nothing I've tried works to change the time. Can some one please let me know the proper way to set the time?
tom
October 14, 2024, 16:14
Jim Hester
To set the time you simply pull out the winding knob slightly - about a quarter of an inch or perhaps a bit less - then turn it which causes the minute hand and hour hand to move in the same way as most watches and clocks do when setting their time. If nothing happens with yours then you have something broken inside that needs repairing to restore this function.
