Polishing a brass locomotive clock "Click" to Login or Register
Railway Historian
Site Moderator
Picture of Larry Buchan
Could somebody give me some tips on how to polish a Seth Thomas brass locomotive clock case.
Picture of Peter Kaszubski
Brasso will help but Mike H did some great restoration on those perhaps he will chirp in.
IHC Member 1725
Hi Larry,
There are a lot of things you could use, but my vote goes to Maas polishing crème.
Good Luck,
Tim
Larry,
Maas is great but a bit on the expensive side. I use Blue Magic Metal Polish Cream, you should be able to find it at an automotive store and it works great.
Mike
Posts: 206 | Location: West Virginia in the USA | Registered: November 11, 2012
Sergeant at Arms
Picture of Scott A. Whittey
Aloha Larry
The Air Force chief of Staff uses Flitz on his highly polished Aircraft(speckled trout) I use it on my aircraft as well
http://www.flitzpolish.com/Buy...rHz70CFYeUfgodLCQARg
Mahalo
Scott
Posts: 293 | Location: California City, California USA | Registered: May 05, 2005
I've used Mother's Mag and Aluminum polish for years.It's non abrasive and can be used to polish just about any thing.Bikers use it on their Harleys,I use it on pocket watch cases,gold , nickel and silver.Available in most Auto parts stores.Regards.Norm
Posts: 484 | Location: Georgia in the United States | Registered: August 04, 2010
Railway Historian
Site Moderator
Thank you everybody for the good tips, I have some Flitz and I will give it a try.
IHC Member 1016
If the lacquer is off and you are down to solid brass then any good polish works. Taking lacquer off requires work as well as method.
I've used Brasso and Never Dull.
