January 03, 2014, 20:04
Kim Stuck[Request information on a] webb c ball mantle clock
I have a Webb C Mantle clock and would like find out any information on it. Thanks Kim
January 08, 2014, 13:08
Ken SnowdenA picture of the movement would help in identifying this clock. I think it might be an Ansonia.
January 08, 2014, 13:25
Dave TurnerKen, I think you're right. Here's another similar example:
January 08, 2014, 19:55
Kim StuckHere is a picture of the inside of the clock
January 08, 2014, 20:23
"Curly" SjolanderKim, Your movement looks French to me. Anything readable on the back or on that stamped area?
Curly
January 08, 2014, 20:31
Kim StuckHere is a close up of the manufacturer but I can't read it. Maybe one of you experts know.
January 08, 2014, 21:28
Michael WeifordKim,
The movement in your clock appears to be from around 1860. I believe the name is S.Marti and was awarded a bronze medal at the Paris Exposition in 1860. I also believe the movement is a Japy Frere with the S.Marti name on it. This would make it a very high grade French movement.
I don't believe the Ball Co. made clocks, just as they never "made" watches, but probably imported clocks into the U.S. and sold them with their name on them.
Is the clock slate? If it is then I think the movement is probably original to the case. I'll have to do a little more research before I can say for sure if the Ball Co. plate is correct. Either way it is a very nice quality made clock.
I hope this helps.
Mike
January 08, 2014, 21:34
Kim StuckI believe it is slate it's very heavy. Thank you very much for your information I appreciate it.
