This is a Sessions that I recently restored. It had been painted with an ugly brown enamel when I found it. It also had a broken strike spring which opened the case side when it went. After much scrubbing and wire brushing and a coat of polyurethane this is the result. The works were overhauled also. Does anyone happen to know what model this one is? Joe ![]() | |||
Joseph, This is the "GRAND #3" - 1915. You did a great job with the restoration. You must be very pleased with the results. Thanks for posting it. You wouldn't have a "before" picture would you? The pictures of clocks with that glass have the reverse image. Is the painted side of yours to the inside of the case? Tom | ||||
Tom, I have questions about the image. I have never seen another one reversed like this. I just rechecked to be sure that the image was inside and it is. It appears to be from a stencil and I guess the stencil could be used from either side. Perhaps the worker was hung-over. I found a replacement glass listed on page 78 of the current Timesavers catalog which is reversed from this one and on page 85 they list a decal that has the same orientation as this one but once it is applied it would reverse also. I seem to have a knack for coming up with controversal clocks. I showed a Hamburg American wall clock on the green board and some said that it had been altered. It hasn't. I am sorry that I did not take before pictures. In the future I will make sure I do so. Joe | ||||
Joseph, the reverse stencil seems to make sense. That is what I wanted to find out. I have not seen an example of a reversed image, but imagine that it was easy to do and probably happened. Here is the page from Tran's Sessions book showing your clock, and one with a reverse image glass. All of the ones in the catalogue that had your glass had them as shown in this picture. Interesting. Thanks for the post and your comments. Tom ![]() | ||||
Thanks Joseph for the nice picture of your kitchen clock, nice job restoring it. I too should take before pictures when i restore a clock. ![]() | ||||
