Kern Midget running slow "Click" to Login or Register
IHC Member 2211
Hello, first post.
I am working on a Kern Midget. I went to the Horolover book for the spring size. I found it on Page 84, Plate 1217C. It calls for a .0020" (.051MM) spring.
I have it set up with that spring, and it runs very fast. The pendulum has a very short adjustment, which was all the way up to try to make it run faster. It lost more than an hour in about 4 hours.
Does anyone know if that information is in error and what size spring I should use?
Thanks for any advice. Danny
Daniel Causey
Posts: 7 | Location: Plant City, Florida in the USA | Registered: May 14, 2017
IHC Member 2211
quote:
fast
I meant to say slow here, the clock is running slow.
Daniel Causey
IHC Member 2211
I think I am going to shorten the spring. I see that the bottom cup is adjustable in height. Thanks, Danny
Daniel Causey
IHC Member 2211
As I was shorting the spring, I realized that is not how a torsion clock works. I'm going to try a thicker spring. Thanks, Danny
Daniel Causey
IHC Member 2211
I was unknowingly using my 7th edition copy of the Horolovar. The info on that plate is incorrect. As found in my 10th edition, it's the .0023" spring and Unit 12E.
That is all. Danny
Daniel Causey
Life Achievement
Military Expert
Picture of Greg Crockett
Thanks for the notes about these clocks. It's been many years since I worked on one of these.
