Mainspring length???? "Click" to Login or Register
posted September 28, 2012 14:35
I need to replace the Strike side mainspring on a Pequegnat Greacin mantle clock. I measure the width at 16mm and the thickness at .40mm. How can I determine the length? I am reluctant to unwind it and stretch it out as I can see where the spring is broken almost all the way across the width and do not want it to bite me.
Posts: 3 | Location: Ontario in Canada | Registered: September 26, 2012
IHC Member 43
posted September 28, 2012 20:05
John, You have to take it out sometime anyway, so might as well put your face mask and gloves on and get out the spring winder. Is it in a barrel or is it an open spring?
Curly
Posts: 255 | Location: Ashland, Wisconsin U.S.A. | Registered: November 22, 2002
posted September 28, 2012 20:24
Thanks for responding Curly: The spring is not in a barrel. I can remove the spring from the wheel without stretching it out. I was hoping there was a table or a spec by clock maker somewhere.
posted September 28, 2012 21:42
I was able to finish the break in the spring and measure the 2 pieces. Thanks for your help. Smile
