American Tavern Clock(?)Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| Vienna Regulators IHC Member 313 |
Was in Quebec City last fall and stopped at a antique store when I noticed a small tavern or public clock that I thought was English. Price was right, case was in need of restoration so in the car trunk it went wrapped in a old blanket.About a month latter I was over at Gilhams Antique Restorations about some other items being restored ans suddenly remembered the clock in the boot.Typical of the clock I attract it was even more ditry and grundge ,needed a good going over for patching and stick shellac fo the knicks.Suddden shock when I pulled the dial and a small banjo type movement appeared. Pend length is 6 inches less then a normal banjo.Does anyone know the maker of this type of clock? Dial is 13 inches. Thanks Doug Doug Barr NAWCC Member 91585 Chapter 185 Member 313 ![]() | ||
movement Doug Barr NAWCC Member 91585 Chapter 185 Member 313 ![]() | |||
Doug, I have not found the exact case that you show. I did find one with somewhat similar lines that is a Willard. The picture below is from the book "Simon Willard and His Clocks" by Husher and Welch. Many of the Connecticut clockmakers used a similar style, however, one detail I noticed is the smooth trapezoid around the center arbor. Many used this style, yet most had a bulge where the pendulum shaft exits the trapezoid. This one matches the one in your picture. This movement is from a Simon Willard banjo. Probably somewhere around 1830. Tom Seymour NAWCC# 41293 IHC Executive V.P. ![]() | ||||
Thanks Tom, D.Barr Doug Barr NAWCC Member 91585 Chapter 185 Member 313 | |||
