Help with Lathe Work on Hard Steel "Click" to Login or Register
I have a shaft made of hardened steel and I am seeking someOne with carbide tools and lathe to make one. It is a arbor shaft used in a Drone brushless motor.
Normally buying a replacement motor is inexpensive and easy.
The Drone is a Skydio 2 and parts are not available and the company is not sharing the motor specs for am DIY.
There are two diameters and a Cir Clip groove, overall length is about 1.5 inches.
One end inserts into the coil side, other sticks through the magnet bell and accepts the center hole for the propellor.
I can be reached at jamesfthorman@gmail.com
Any help is appreciated.
Posts: 146 | Location: New York in the USA | Registered: September 23, 2018
