Removing part of wooden clock case "Click" to Login or Register
posted April 14, 2006 23:50
Hello:
I have just received an empty clock case that I won on eBay. It is a gingerbread kitchen clock case that I bought for the wooden side pieces. Now--how do I go about removing those pieces without damaging them? The bottom of the pieces seem to loosen from the base but the sides of the pieces seem firmly attached.
Any advice would be greatly appreciated!
Pattye
Posts: 119 | Location: Lookout Mountain, Georgia U.S.A. | Registered: October 14, 2004
posted April 15, 2006 09:14
Pattye,
Sometimes I have used a jeweler's saw between at the glue joint to separate pieces. This does not always work as the saw frame sometimes interferes.
Best luck
Dick
posted April 15, 2006 09:27
Pattye, look for signs of nails going from the inside body of the case into the side pieces. Most times you can 'pry' them apart being careful not to mar the wood.
Mike
aka 'clock whisperer'
Posts: 152 | Location: Telford, Pennsylvania USA | Registered: May 21, 2005
posted April 15, 2006 17:49
Mike and Dick,
Thanks so much for your suggestions. I didn't have the saw on hand but did manage to pry out the interior tacks with no damage. I really appreciate your responses.
This message board continues to be a great source of support and communication. Thanks to all who are so helpful!
Pattye
posted April 18, 2006 17:22
Pattye,
An old restorers trick is to use warm vinegar and water to loosen the hide glue. Unfortunately the water will raise the grain and sanding is required. Sometimes just heat will do the trick. Cook the basic case in the oven at the lowest setting, checking often to see if the pieces have come loose. Then get it out quick before the wood dries out too much.
Posts: 179 | Location: Charlotte, Michigan U.S.A. | Registered: March 31, 2004
posted April 18, 2006 23:11
Thanks Bruce
Those are also good ideas to put in my bag of tricks.
Pattye
posted April 19, 2006 00:13
If you are lucky, and they used hide glue, heat will release it. Just heat it with a blow dryer and it should release.
Posts: 131 | Location: Houston, Texas USA | Registered: February 12, 2003
