Laquer removal from 40 day clockGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hello, Does anyone know how to remove the laquer from the old 400 day brass clocks? I am particularly concerned about any mechanical (buffing) technique on brass plated steel bases. Thanks. Jim Fischer | |||
| IHC President Life Member |
Hi Jim, There are a number of different finish removers available in hardware store paint departments, checking the packages and instructions may provide some direction. Personally I use plain old lacquer thinner, but it is expensive and becoming increasingly difficult to find. I definitely agree with you on wanting to use a chemical for removal rather than an abrasive. By the way, to avoid fumes I wait for a nice day and do that kind of work outdoors. Let's see what others suggest. Lindell | |||
Up here in chapter 6, most of the guys use oven cleaner, the kind that isn't heated. | ||||
| IHC Member 1101 Site Moderator |
I can tell you that after you get the old laquer off, use some simichrome to clean the brass back to a beautiful shine. As suggested by Lindell, I then used Testors Clear Gloss spray to preserve the shine. Steve | |||
