September 15, 2012, 15:09
Jack WinchMantle Clock Maker Identification
I have a wooden cased, striking mantle clock which I now have managed to get more or less 'in beat'. I wondered if anyone could help identify the maker and date. The trademark on the movement is a standing lion inside a circle, embossed on the backplate of the movement.
Many thanks in anticipation!
September 15, 2012, 20:41
"Curly" SjolanderJack, Hard to tell from your picture what type of clock it is. The lion in a circle was used by Wecker in Germany from about 1905 to the 1990's I think. They made primarily alarm clocks. More pictures might help with an ID. Hope this helps.
Curly
September 16, 2012, 02:48
Jack WinchThanks for your reply, "Curly"!
I've now attached two slightly better photos - one of the clack face and casing, the other of the movement inside the rear of the casing.
Does this help with identification?
There's a little adjuster at the top of the face which connects with a cog at the top of the pendulum. There's a gnurled wheel on the pendulum bob for moving it up and down - so I wondered what might the other adjuster above the XII be for?
September 16, 2012, 02:52
Jack WinchHere's the clock's face and casing:
September 16, 2012, 07:32
Eddie G. HinesGS JACK, I ONCE HAD A FRENCH CLOCK THAT HAD THE SAME IDENTICLE LOGO, ALSO THERE IS A GROUP OF NUMBERS ON THE BACK PLATE AT THE BOTTOM OF THE PLATE, THERE SHOUL BE NUMBERS ON BOTH SIDES OF THE BACK PLATE PILLAR AT THE BOTTOM THE NUMBERS TO THE RIGHT CAN BE TRANSLATED TO GIVE YOU THE PENDULUM DROP THAT IS TYPICAL ON FRENCH CLOCKS. THE SMALL ADJUSTMENT AT THE TOP OF THE DIAL CAN BE USED IN CONCERT WITH THE PENDULUM RATEING NUT FOR A MORE PRECISE ADJUSTMENT. HAVE A GOOD DAY,EDDIE
September 16, 2012, 13:45
Jack WinchThanks for your help, Eddie!
September 16, 2012, 17:26
Norman MayberryThe standing lion looks like the one that Muller uses.I've never seen it in a circle though.Regards.Norm
September 16, 2012, 19:50
"Curly" SjolanderJack, Thanks for the additional photos. Now I can see that the clock definately looks French. I will have to do some more research on the trademark.
Curly
