May 23, 2004, 22:10
Stephen L. Russellone handed simple clock.
Here is a clock I bought in a Richmond jewelry store,many years ago.
the first picture looking up from the weight.
May 23, 2004, 22:13
Stephen L. Russellthis is the simple movement.
May 23, 2004, 22:13
Stephen L. RussellHere is the whole clock.. less the hanging weight.
May 26, 2004, 20:25
Andy KrietzerStephen,
Was it new when you got it? My brother got a similar one in the early 1970s that was plastic, a kit by Lindberg, I think. They started making a lot of these after the 1892 Columbian Exposition, but the ones I have seen were all wood.
Does it run?
Andy
May 26, 2004, 20:29
Stephen L. RussellAndy,It runs sporadicly,and never for longer the 15 mins...needs constant adjusting.
It was,I'm told a reproduction from Germany,hand riveted etc.
May 26, 2004, 21:35
Kevin PestorInteresting clock Stephen, i have not seen others like it.Is it mostly made of some kind of metal?
May 26, 2004, 21:47
Tom SeymourI have a couple of the "Columbus" clocks. They were, as mentioned, wood or plastic. I will post a picture as soon as I get a chance. I'm sure most have seen these before.
May 27, 2004, 00:24
Stephen L. RussellKevin,it is a soft metal....I assume Iron.If you look closely you may see what looks like slag.
