April 14, 2006, 21:53
Grant PerrySeth Thomas Calendar-Info??
Good evening:
I picked up this Seth Thomas on a buy it now earlier today. Can anyone tell me what model this is, and what the top should look like? I assume it is missing. As always, thank you!
gp
April 14, 2006, 23:11
Tom SeymourGrant,
It looks like a Parlor #3. The top would gradually slope in a straight line from each outer edge to a point in the middle. Not very high. I will scan a picture from Tran's book when I get a chance. I can't do it right now. (Unless someone beats me to it.)
April 15, 2006, 11:52
Grant PerryThanks Tom. I appreciate the input.
Do these often go missing, and if so, does someone make replacements?
Thanks again,
gp
April 15, 2006, 21:00
Tom SeymourWhat do you think of these? It looks like it to me.
The pictures are from Tran's Seth Thomas book , Vol 1.
Top pieces are frequently lost from clocks.
April 17, 2006, 08:42
Grant PerryTom:
Great. Thank you again. Does anyone make replacment tops for these?
gp
April 17, 2006, 15:22
Derek B. PhelpsGrant, I'm not sure anyone makes replacement tops for these clocks. And, I'm also not sure what is missing? From the pics you posted there appears to be something on top. It may be that it only needs to be reveneered. Can you post a pic of just the top.
A couple other options is to try and find an empty case or a badly damaged one that you can either cannibalize to complete this one or at least get measurements to reproduce the top or find someone in your area that has this model where you can use one to make a duplicate copy. You don't see empty cases very often and even badly damaged one are pretty expensive. I saw this model at the Cincinnati regional mart that was missing the dials and needed a lot of veneer work and I think the fellow wanted $800 or $900 for it. Good luck!
Derek
April 17, 2006, 16:11
Pattye JonesGrant:
Here is a photo of the Southern Calendar Co. Fashion #1, the case of which seems to be the same as the Seth Thomas Parlor clocks except for the side molding. It has a Seth Thomas movement, as well. It is a part of my father's collection.
He had two of this model, one has a missing top so I would like to have one also, if you find a source.
Pattye
