Customer asked me to fix this mess "Click" to Login or Register
Picture of Paul Davis
ello my name is Paul, I had a good customer ask me if I could do something with his glass ball clock, that he had taken to a so called watch maker and he took out the original movement cause he couldn't get it to run right, of course it was a swiss movement, and he rigged this dollar watch movement in it and gave it back to him..of course he was not happy, so he asked me and I told him I would do what I could to at least make it worth something again, my first thought was to take out all the trash and junk it ( see pic of bag of junk) I took the ring out and soldered the collar to the ring, I inserted a rubber washer to hold the Waltham movement in place( yes a 18 size Waltham movement) , I used a square piece of hardened steel to file down and use as the stem, I used a tap and die set to cut threads inside the collar to hold the sleeve, and I used a large crown soldered to the top of the stem to make it look like original..considering what I started with I think this thing turned out pretty nice for one of a kind( as far as I know) and my customers reaction was WOW, that looks super, decide for yourself and leave your comments for all of us to learn from..thanks
Paul Davis
Posts: 672 | Location: Missouri in the USA | Registered: May 01, 2015
Bag of junk
Paul Davis
Bag of junk
All the old pieces
Paul Davis
Old pieces
Finished front side
Paul Davis
Front side
Rear of ball clock
Paul Davis
Rear of clock
Nice job, Paul.
Whoever discarded the original "guts" should be listed on this, the national, and any other watch or clock repair sites as someone to avoid.
I have one question, though - Was the case too small to insert an 8 day size 37 Waltham clock?
Site Administrator
Picture of Phillip Sanchez
Paul, great work. Thanks for sharing that.
Thanks for the replies and yes David the opening to hold the movement was only about 1/2 bigger than the 18 size movement I used, but the 18 was right at the same as the original. thanks
Paul Davis
