Longines watch identification queryGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hi. A friend of mine received a watch. I wondered if anyone could identify the caliber or type of watch. He doesn't know how to open the back, so I only have photos of the case, dial and band. The size of the watch, including case, is 34 mm and was described as a "gold watch." If anyone recognizes the type from the picture, I'd appreciate the information. Jessica ![]() | |||
This is the front of the watch with dial. ![]() | ||||
Jessica, tell your friend I don't believe the back on this paticular watch opens. I have a similar styled vintage 14K Omega (c. 1960's.) The movement can be taken out only after the crystal has been removed and the stem taken out. Dave Freeman IHC Member 321 | ||||
That's interesting, Dave. The watch is from the 1950's, which I meant to mention. I've looked through the Longines book and on ebay, and don't see any cases like this. Do you think the case is an after-manufacture decision, so that the movement could be one of the standard ones, possibly shown (in the books) in a different style case? Jessica | ||||
Jessica, These cases were common in the 50's and 60's. The advent of good quality plastic crystals made them possible. I have a Hamilton, Elgin, Longines, and a Bulova in this type of case. As DAve said, the movement comes out through the front. The plastic crystal is removed with a crystal suppressor. The stem is a split stem that allows the crown to snap free. Then you drop the movement into your hand. To reassemble--drop in the movement, snap in the stem, and reinsert the crystal. One should not try this without a crystal suppressor. Tom | ||||
| IHC Member 155 Bulova Watchmaker |
The movement most certainly comes out from the front as Tom and Dave have said. I would place this watch in the later 1960s. I doubt it would be 1950s. This type of band arrangement was typical of the mid to late 60's and was used in the 70s as well. I can't tell if the watch is an automatic or wind up so I can only guess at the movement. Since I don't like guessing I won't. Rich Kuhn IHC Member 155 | |||
Hi, Rich. After looking at ebay for quite a while, I also concluded that the movement might be fromthe 1960's, based on the look of the outside. I also wonder if it could be automatic, since the only watches with those dials that I noticed were automatic. The owner said manual--or at least didn't disagree when I asked him--so I'm not sure. Maybe he only meant not quartz. I may check with him further. However, I'm sure he wouldn't want to go into taking off the crystal, etc. Thanks, Jessica | ||||
