June 19, 2007, 22:39
Jim RobsonWaltham WW
Hi all, I just got this Waltham. The case is rough, but the porcelain dial and damascened movement are great. Can someone venture an estimate of age?
June 19, 2007, 23:34
Adam M. DubinJust by the appearance I would venture immediate pre-WWI era, but I'm sure one could look up the serial number of the movement, no?
June 20, 2007, 08:56
Jim RobsonYou are right Adam. There is a Waltham
database and it says this is model 1907. That means that the watch was introduced in 1907. They had a production run of 10,000 of which mine was near the end.
You were also right about this being pre WWI.
Thanks and regards, Jim
June 22, 2007, 12:04
John ArrowoodIs there a name and indication of case material on the inside of the back? It looks a lot like those re-cased movements from the 1920-s and 1930's.
June 22, 2007, 14:28
Dan MitchellLooks like chrome plated base metal. Hamilton made similar in 1917, when wristwatches at last became acceptable for a man to wear.
The movement could be a negative set ex-ladies PW movement.
Dan.
June 22, 2007, 14:57
Jim RobsonHi John & Dan, Here is all of the info from the database. The footnotes say that the model number is the year the watch went into production. Did ladies pocket watches ever get as small as 0s? and would they have had the pendant at 3 or 12?
John, the inside back cover say's "Illinois Watch Case Co. Spartan - 0607050" It does look like chrome plated base metal.
First: 15715501 Last: 15725500
Model: 1907
Material: U Grade: No. 161,
Jewelling: Jewels: 7
Balance: Bal: Breguet Spring
Style: HC Style:
Htg.
Hope this info helps you guys to identify it better.
Thanks, Jim
June 22, 2007, 21:53
Donald B. Dahlberg0 size was the most common size for women's watches. They were both open face and hunter movements and cases.
Your movement dates about 1908.
Many of the watch companies over produced woman's size 0 and 3/0 movements in the 1910 era. When men's wristwatches became acceptable in WWI, many women's movements were cased or recased in men's wristwatches. One way to identify your case is to send a picture to research@nawcc.org with your membership number. We can try to find it in the jewelry supply catalogs of that era. No gurantee, but it is worth a shot.
We do know that this type of circular cushion case was popular during the WWI and post WWI era. Hamilton introduced their first wristwatches in a similar case in 1916. (They reused this style of case in WWII, but with a smaller movement).
Don
June 23, 2007, 15:24
Jim RobsonHi Donald, Thanks for all that good information. I'll take you up on that research offer. You will have that request (and a few others) on Monday morning.
Best regards, Jim
