June 10, 2006, 13:01
Scott CerulloReal Cariter Tank?
Hi everyone.
I recently had this Cartier tank brought to me. When I took the watch apart, I found that the movement is soldered to the case back.
Could someone tell me if this is something that Cartier did? The owner asked if I could sell the watch for him, but I am concerned about the soldering.
Please look at the pics and let me know if this is something you have seen before.
Scott
June 10, 2006, 13:03
Scott CerulloI believe the dial and the crown to be replacements.
June 10, 2006, 13:04
Scott CerulloInteresting way the case is screwed to the bezel.
June 10, 2006, 21:33
Rich KuhnScott,
I have yet to see a maker solder a movement in place are you sure the movement is by Cartier? I can't tell from the picture of the dial side. This may be a put together piece. The case does look real from what I can see.
June 12, 2006, 19:20
Scott CerulloThanks for the reply Rich. I was asked to list this watch on Ebay. In the description, I will state that I was unable to verify the maker of the movement.
June 15, 2006, 15:49
Dan MitchellI suggest the movement is a replacement, and was found to be just a little too small for the aperture - so was fixed in position to prevent it moving around in the case back in use.
Cartier or their makers would never build an un-servicable watch in this way !
Dan
June 20, 2006, 22:16
Dave FreemanScott,
I'm highly suspicious of the dial on your watch, and likewise I share the same concern that Rich Khun mentioned. From your picture your dial doesn't appear to have the classical Cartier feature of having the Cartier name as one of the legs a Roman Numeral i.e. normally contained within the Roman Numeral VII.It's possibly there but I can't see it from your picture. Also I haven't seen the name France on a Cartier dial, their watches to the best of my knowledge all say Swiss.
