Gruen Curvex-Ristside Fraternity needs Band (Got one)
February 22, 2010, 22:52
Richard RomeroGruen Curvex-Ristside Fraternity needs Band (Got one)
I had this watch restored which used to belong to my father. I was wondering if anyone knows what kind of band and buckle originally came on the watch and where I can find one now? Any information would be helpful. Also, if anyone has advertisements from Gruen they can post I would appreciate it.
Thank you,
RR
February 25, 2010, 22:09
Samie L. SmithRichard i have never owned one of these i would think any nice leather or croc. band would be okay with a regular type clasp or buckle ..That,a beautiful watch if it were mine i would buy a good quailty band and skip the cheap ones.
February 26, 2010, 18:02
Richard RomeroSamie,
Thank you for the advice. I've been researching this watch and changed the title now that I know the model of the watch. I also changed the description I had earlier to say buckle rather than clasp. I've found two sources for a stamped Gruen buckle. I'm getting closer to finding a nice original Gruen band that will work, but I'm still unsure if I'll be able to find what may have originally came on the watch becuase according to information at
T H E G R U E N W A T C H C O M P A N Y 1929 - 1940 "A normal leather strap is awkward to use with these watches, because the buckle ends up on the little-finger side of the wrist, opposite the watch. Some originally had special straps, which were extremely long on the buckle end, but very short on the other end". It would be nice if someone who has one of these special straps could post a picture and if anyone comes across one for sale they could contact me. I'll probably have to move this post to items wanted.
Thanks again,
RR
February 27, 2010, 09:55
Scott AllisonGreat watch, Richard. Is it a 5/8" lug spacing? If you can get an accurate lug measurement in MM with a digital caliper, and the length required, I can look through my inventory to see if I have something. I know Erd-Ber made straps that were short on the buckle end and long on the other, and I think I have a couple.
Thanks!
February 27, 2010, 09:59
Scott Allison...I meant to say long on buckle end...
February 27, 2010, 13:11
Richard RomeroHi Scott,
It is 16mm on the watch end and the buckle side is 14mm. I'm looking for something black.
Thank you,
RR
February 27, 2010, 13:19
Scott Allisonthanks, what is the length required: measure around your wrist, then subtract the length of the watch at spring bart centers, thanks!
February 27, 2010, 14:20
Richard RomeroMy wrist measues 8 inches and the spring centers on the watch are 1.2 inces apart. Around 6.75 would be the length if the strap was tight. Also, I can get a 13mm or 14mm buckle. Thanks,
RR
February 27, 2010, 21:52
Scott Allisonplease email me directly at:
vintagewatchbands@timesofplenty.com
thanks!
February 28, 2010, 08:38
Dr. Debbie Irvine
Thanks Scott!
February 28, 2010, 15:52
Clive DriscollScott
A customer today asked me if i can get hold of military watch straps. Is this something that you can provide?
What he means by military is the wide strap but with a thin central strap that goes though the wire lugs and under the back of the watch, which was often used for first world one type watches.
Kind Regards
Clive
February 28, 2010, 16:25
Scott AllisonThanks, Clive. I do have those, $24.95 shipped anywhere:
March 03, 2010, 14:20
Clive DriscollThank you Scott- I will speak to my customer.
Kind Regards
Clive
March 04, 2010, 12:39
Scott AllisonRichard:
I sent you an email a few days ago, maybe your spam filter got it?
Scott
April 22, 2010, 12:12
Richard RomeroHi All,
After the above post Scott and I corresponded and Scott has a very nice brown drivers band however I really wanted to find a black one to match the dial and so I could use the watch for formal occasions.
Scott,
Thanks for finding a suitable band, if I didn't find a black one the brown one would have also worked out nicely.
After searching online for Gruen specialists I came across a gentleman who referred me to someone who had a large selection of Gruen parts on ebay. I sent them some e-mails and after a few days they found a black suede band.
When I went to install the band it ended up being 17mm instead of the 16mm needed for the watch. I let the seller know I was going to try to cut it narrower with a razor blade. They informed me that wasn't a good idea as .5mm on each side isn't much. He told me to try using sand paper so that's what I did. After a couple hours of careful sanding and fitting here's the finished watch with its new Gruen black suede band.
April 22, 2010, 12:13
Richard RomeroThis 17j caliber 440 Curvex was purchased brand new by my mother as a gift to my father sometime in the 1950's. I purchased the box on ebay.
April 22, 2010, 12:15
Richard RomeroHere it is worn Ristside instead of the top of the wrist.
Thanks again,
RR
May 28, 2010, 10:18
Rick VessRichard,
I am also looking for an original ristside band. Would you mind giving me a private hint of the seller?
Rick
