Gruen Curvex-Ristside Fraternity needs Band (Got one) "Click" to Login or Register
Picture of Richard Romero
I had this watch restored which used to belong to my father. I was wondering if anyone knows what kind of band and buckle originally came on the watch and where I can find one now? Any information would be helpful. Also, if anyone has advertisements from Gruen they can post I would appreciate it.
Thank you,
RR
IHC Member 376
Watchmaker
Picture of Samie L. Smith
Richard i have never owned one of these i would think any nice leather or croc. band would be okay with a regular type clasp or buckle ..That,a beautiful watch if it were mine i would buy a good quailty band and skip the cheap ones. Smile
Samie,
Thank you for the advice. I've been researching this watch and changed the title now that I know the model of the watch. I also changed the description I had earlier to say buckle rather than clasp. I've found two sources for a stamped Gruen buckle. I'm getting closer to finding a nice original Gruen band that will work, but I'm still unsure if I'll be able to find what may have originally came on the watch becuase according to information at T H E G R U E N W A T C H C O M P A N Y 1929 - 1940 "A normal leather strap is awkward to use with these watches, because the buckle ends up on the little-finger side of the wrist, opposite the watch. Some originally had special straps, which were extremely long on the buckle end, but very short on the other end". It would be nice if someone who has one of these special straps could post a picture and if anyone comes across one for sale they could contact me. I'll probably have to move this post to items wanted.
Thanks again,
RR
Great watch, Richard. Is it a 5/8" lug spacing? If you can get an accurate lug measurement in MM with a digital caliper, and the length required, I can look through my inventory to see if I have something. I know Erd-Ber made straps that were short on the buckle end and long on the other, and I think I have a couple.
Thanks!
Posts: 88 | Location: Southern California in the USA | Registered: June 23, 2008
Hi Scott,
It is 16mm on the watch end and the buckle side is 14mm. I'm looking for something black.
Thank you,
RR
thanks, what is the length required: measure around your wrist, then subtract the length of the watch at spring bart centers, thanks!
My wrist measues 8 inches and the spring centers on the watch are 1.2 inces apart. Around 6.75 would be the length if the strap was tight. Also, I can get a 13mm or 14mm buckle. Thanks,
RR
please email me directly at:
vintagewatchbands@timesofplenty.com
thanks!
Administrative Assistant
Picture of Dr. Debbie Irvine
Thanks Scott!
Smile
Posts: 5861 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
Scott
A customer today asked me if i can get hold of military watch straps. Is this something that you can provide?
What he means by military is the wide strap but with a thin central strap that goes though the wire lugs and under the back of the watch, which was often used for first world one type watches.
Kind Regards
Clive
Posts: 264 | Location: Westbrook, United Kingdom | Registered: June 15, 2007
Thanks, Clive. I do have those, $24.95 shipped anywhere:
Thank you Scott- I will speak to my customer.
Kind Regards
Clive
Richard:
I sent you an email a few days ago, maybe your spam filter got it?
Scott
Hi All,
After the above post Scott and I corresponded and Scott has a very nice brown drivers band however I really wanted to find a black one to match the dial and so I could use the watch for formal occasions.
Scott,
Thanks for finding a suitable band, if I didn't find a black one the brown one would have also worked out nicely.
After searching online for Gruen specialists I came across a gentleman who referred me to someone who had a large selection of Gruen parts on ebay. I sent them some e-mails and after a few days they found a black suede band.
When I went to install the band it ended up being 17mm instead of the 16mm needed for the watch. I let the seller know I was going to try to cut it narrower with a razor blade. They informed me that wasn't a good idea as .5mm on each side isn't much. He told me to try using sand paper so that's what I did. After a couple hours of careful sanding and fitting here's the finished watch with its new Gruen black suede band.
This 17j caliber 440 Curvex was purchased brand new by my mother as a gift to my father sometime in the 1950's. I purchased the box on ebay.
Here it is worn Ristside instead of the top of the wrist.
Thanks again,
RR
Richard,
I am also looking for an original ristside band. Would you mind giving me a private hint of the seller? Smile
Rick
Posts: 141 | Location: Michigan in the USA | Registered: October 13, 2005
