How to open this wristwatch?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I could use some help on what I need to buy, to open my wristweatches. Most of mine have those indentions in, and around the case, that you use to open it. Another question is, a watch I just picked up, makes a sound like it's real loose inside, so what should I know, or do, before I try to open it? This one is called a Tourneau, and you can see the back I was talking about. Thanks, Sheila ![]() | |||
| Watchmaker |
Hi Sheila, You need a couple of things to open cases similar to your Tourneau... a case holder and a case wrench. Check out this page for holders: http://www.julesborel.com/horological/page131.htm I have many more expensive ones, but the second one listed on this page is actually pretty good for the six bucks. This case holder can be held in a small bench vice. Wrenches: http://www.julesborel.com/horological/page136.htm I have to recommend the second one on this page as it's of much better construction than the $13.95 one. The cheaper one is OK, I guess, if you mainly intend to open lesser expensive watches. You will sometimes find the $44.95 model on eBay for much less, in used condition. Sometimes it may be labeled "Vigor" rather than "LG", but it's the same wrench. Just make a mental note of all the attachments you see in the pics, and be certain that a used one is equipped with everything before buying it. Always try to open a watch over something that will catch anything that falls out. This is especially important when you hear something loose inside. There is a "catch tray" on most watchmakers benches that addresses this issue. Just go slowly, adjust the wrench for a proper fit, and try not to let it slip, or you'll end up with a scratched case back. BTW, I have no affiliation with Jules Borel other than purchasing from them as a customer. Gene | |||
Thanks to Gene, I got it now! Hi Gene, Thank you so much for the links. I have the wooden watch holders, but I'm going to pick up this one too. I can't figure out how the watch will go into the ones I have, besides, I use it for pocket watch movements anyway. I like the idea of having them for both styles anyway. I had looked at the wrenches, but had no idea which one to get, and this one is just like the ones I found on ebay and decided to get. This one looks nicer though. Thanks again guys! Sheila | ||||
