Two Piece Stems "Click" to Login or Register
Picture of Brian C.
posted September 28, 2006 05:38
I'm over here again.
It seems no matter how many times I tell my friends I don't work on battery watches, they keep bringing them to me and ask, can you fix this? I have a question, How do you tell if a watch has a split stem? I know some movements have a little button that you push and then pull the stem out. What is the correct way to recognize and remove a split (two piece) stem?
Brian C.
IHC Member 155
Bulova Watchmaker
Picture of Rich Kuhn
posted September 28, 2006 06:34
Brian,
Two-piece stems or slit stems as they are sometimes referred to, are used on cases that the back does not come off. These cases are called one-piece cases. The movement comes out from the front of the case after the crystal is removed. The following pictures show the process. Hope this helps
Rich Kuhn
IHC Member 155
IHC Member 155
Bulova Watchmaker
posted September 28, 2006 06:35
the tool
Rich Kuhn
IHC Member 155
IHC Member 155
Bulova Watchmaker
business end of the tool
Rich Kuhn
IHC Member 155
IHC Member 155
Bulova Watchmaker
posted September 28, 2006 06:36
The crystal removed
Rich Kuhn
IHC Member 155
IHC Member 155
Bulova Watchmaker
the movement and stem and crown
Rich Kuhn
IHC Member 155
IHC Member 155
Bulova Watchmaker
posted September 28, 2006 06:37
Female part of the stem
Rich Kuhn
IHC Member 155
IHC Member 155
Bulova Watchmaker
posted September 28, 2006 06:38
Male part of the stem
Rich Kuhn
IHC Member 155
Picture of Brian C.
posted September 29, 2006 04:57
Thanks Rich,
That's exactly what I wanted to know. The 2 piece stems, are in one piece cases.
Brian C.
